Blue devil head gasket sealer - Page 2 - JeepForum.com
post #16 of 25 Old 05-18-2013, 12:01 PM
doityourselfMM
doityourselfMM's Avatar
Assuming the heads were not warped when you installed them, how did you torque them? They should be done in a circular pattern, starting from the middle of the head and rotating outwards. They need to be torqued in stages, increasing the torque each cycle. And with an accurate torque wrench.
Improper torqueing could cause them to warp. Not sure they would crap out (if improperly torqued) that quickly, though.
I am suspicious that they were OK when you bought them.
doityourselfMM is offline
post #17 of 25 Old 05-18-2013, 12:20 PM Thread Starter
javis4x4
Originally Posted by WJ4x4LIFE View Post
Agreed, with the statement above as your seemed to be an "immediate" with your mechanical skills.
I will help a little with these tests.
#1 "Compression Test"
* Simplest Test *
http://www.lislecorp.com/divisions/products/?product=75
#2 "Leak-Down Test"
* Simplest Test * = DIY friendly as possible...
http://www.lislecorp.com/divisions/p...s/?product=406
Also you seem to be in the DFW! Hope to see you around....
yea im actualy in grand praire and right accross from me is a great spot with great trails !, you ever in this area you should pm me to hit the trils
javis4x4 is offline
post #18 of 25 Old 05-18-2013, 12:24 PM Thread Starter
javis4x4
i did torque then in the order that the book says, but i did not know about increasing the touqua as you go
javis4x4 is offline
post #19 of 25 Old 05-18-2013, 01:06 PM
WJ4x4LIFE
Back to the real question on hand, there is a few products that Blue Devil has to offer.
Product #1.
http://www.gobluedevil.com/headgasketsealerproduct.html
*Disclaimer* You will need to flush the coolant system a few times and then you can chance the sealer treatment. Professionalism out the door, this **** does have create a foam solvent and can cause internal issues. I could care less what the manufacturer claims or says!!
Product #2.
http://www.gobluedevil.com/pourngoproduct.html
We have tested this product before on a head gasket issue before, and this **** left so much blockage on both cylinder heads, then before of course. Afterwards we still had the same issue, and worst by the way.
WJ4x4LIFE is offline
post #20 of 25 Old 05-18-2013, 03:48 PM Thread Starter
javis4x4
Well I guess I'm going to have to rip apart my motor again instead of dumping this in my engine.
javis4x4 is offline
post #21 of 25 Old 05-18-2013, 03:49 PM
lazyWJ
2006 XK Commander
Sealer can work in small problems, and in fact is so effective that Subaru implemented it as routine maintenance for many years on it's vehicles that were notorious for head gasket seepage (subaru cooling system conditioner = leak stop). In a case as severe as this where you are seeing steam/coolant leaking, there's not a hope in hell that any sealer is going to help. Period. There's a major issue here, a broken head or a gasket damaged on installation. You just don't get coolant pissing out from a warped head or minor sealing issue, this is a serious **** up.
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #22 of 25 Old 05-18-2013, 10:30 PM
BIGBADWOLF
I would think twice before using this stuff. This stuff contains silicates (water glass) so if it does not seal your leak and gets into your oil its bye,buy engine.....remember "cash-for-clunkers", they poured silicates into the oil to seize the engines. If a head gasket is just seeping a little coolant Bars pellets are the safest bet. I have successfully stopped several head gasket leaks with Bars. While not a permanent fix it can buy you some time. I have an S-10 that was leaking so bad from the head gasket it was shorting out the plug wires. I put Bars in it and it stopped leaking...that was 11 years ago!
BIGBADWOLF is offline
post #23 of 25 Old 05-19-2013, 11:27 AM Thread Starter
javis4x4
Bar huh ,I've never heard of it. But if you used it in your S10 and its good after 11yrs. Sounds like I might try that to buy me some time.
javis4x4 is offline
post #24 of 25 Old 05-19-2013, 01:09 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
if you didn't torque it in stages you probably warped the heads again.
do it right
his sounds like an external coolant leak, yours is going into the cylinders, and badly from the sounds of it.
don't do it half butt style. do it right.
ratmonkey is offline
post #25 of 25 Old 05-19-2013, 01:15 PM Thread Starter
javis4x4
this is how i did it and also touque them down to 60lbs like it was said to be done
javis4x4 is offline
