blown head gasket - JeepForum.com
post #1 of 11 Old 09-04-2011, 08:45 AM Thread Starter
jmccallie99wj
1995 XJ Cherokee
blown head gasket
Long story short, I was having problems... when I went to change my oil, I had coolant in my oil. So blown head gasket, right? Is this something I could do myself? Also is there a lower and upper head gasket? And should I replace both? Also another option is I found another 99 limited that got rearended. It has 85k on the motor, id get the entire jeep for 1300. My question is what would you guys do? Tackle the head gaskets, with other possible problems. Buy the other wj and swap motors part out the rest and scrap the body...
Im somewhat mechanically inclined but have heard doin the head gaskets can be a pain...
jmccallie99wj is offline
post #2 of 11 Old 09-04-2011, 11:30 AM Thread Starter
jmccallie99wj
1995 XJ Cherokee
Anybody?
post #3 of 11 Old 09-04-2011, 12:00 PM
AsphaltCowboy
2003 WJ
there is just one head gasket, between the head and the engine block. I'm assuming you're thinking of a dirtbike engine where the head separates from the cylinder and then the cylinder can separate from the block.
I've never replaced one on a jeep but I would think it would be significantly easier to replace the gasket than to swap engines and have to deal with a parts truck, but that all depends on how much room you have.
Also when you replace the HG make sure to have the head(s) resurfaced at a machine shop.
Is this the 4.7 or the 4L?
AsphaltCowboy is offline
post #4 of 11 Old 09-04-2011, 04:41 PM Thread Starter
jmccallie99wj
1995 XJ Cherokee
4.7, I don't know how true this is but someone said that ill have to redo my timing and mess with the cams and a bunch of other crap... and that the exhaust manifold bolts will prolly all break. I guess just trying to figure out how difficult replacing the HG will actually be? My origional motor has 180 k on it so im also afraid I could have other problems due to the bad HG...
post #5 of 11 Old 09-04-2011, 05:12 PM
yj98joe
Do the head gaskets, way easier than an engine. It won't effect the timing if you don't turn the engine over while apart.
I just did a set on my brothers Chevy pu. Wasn't that bad. 2 afternoons.
Wait....... Is this engine overhead cam ? It's still easier than an engine
yj98joe is offline
post #6 of 11 Old 09-04-2011, 05:28 PM
AsphaltCowboy
2003 WJ
yes they're SOHC
post #7 of 11 Old 09-04-2011, 05:38 PM
hammerz71
yeah, overhead cams. Head gasket isn't terrible, just time consuming, but you better make sure you don't have a cracked head, 4.7 is almost as prone to it as it is a head gasket.
2002 Jeep Grand Cherokee Overland
Old Man Emu HD coils, 265/65/17 Nitto Terra Grapplers, Warn M8000, home made light bar, Cepek 130 watt lights, Hella 500s
CURRENTLY REBUILDING THE 4.7 HO ENGINE
hammerz71 is offline
post #8 of 11 Old 09-04-2011, 07:17 PM
sherker55
I wouldn't worry too much about the bolts on the exhaust manifolds, you can just hit them with some pb blaster the day before, and then torch them when you take them off. A buddy helped me replace mine when I had a stud/bolt bust off, and the torch heated it right up, and made it super easy to unscrew...
as far a a swap or a HG change, I would lean towards changing the HG, but with all that milage, I mean you have a 100k more than the rear ended one. like said before, depends on how much room you have to work with in your garage or where ever. start with yours, and see if there are any other problems that you uncover once you remove the heads.
while you have it apart can I suggest putting in the H.O. cams (rockers and springs too)....might as well, unless you don't like an extra 20 hp & 20 tq....
Originally Posted by HaViiK View Post
Send me the number, she can take a ride in a real jeep
Originally Posted by WillMcD View Post
She said call her when your over 4"
sherker55 is offline
post #9 of 11 Old 09-05-2011, 02:34 PM
Jeepdude22
i just got done replacing my head gasket on my 04 4.7. I did it myself (and the help of my brother) but it was fairly simple to do once you get everything out of the way. I ended up taking off the front bumper, grill, EVERYTHING! and it was very simple to do. 185 for the entire gasket set, 120 to get the heads cleaned, and milled. The Owner before me obviously took them apart and left huge scrape marks in the heads which caused the problem in the first place.
Jeepdude22 is offline
post #10 of 11 Old 09-05-2011, 02:54 PM
shockracer
I'd try to fix what you have and buy the wrecked jeep and part it out. Milage is just that, yours could be clean and problem free where as the one you found could be neglected and wore out. Does yours seem tired, knocking, smoking?
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #11 of 11 Old 09-07-2011, 10:52 AM
TOW_HOOK
1957 CJ3B
Wj
if it's a 4.7 put some time aside, it took me a weekend just to get the heads off. and 2 trys to find the old chains had streched, and the timing was off 1 tooth or less !! total time down was 3 months ! it can be done, know what your getting into. take your time, and have only trusted friends help you. i'm not sure i'd do it again... but it might go faster, now that i have done it 3 times.. lol
57 3b classic krawler /93 xj r.i.p. / 95 yj daily driver / 02 wj wife's ride / 98 xj wanta be rock krawler
TOW_HOOK is offline
4.7L Blown Head Gasket pzappa WJ Grand Cherokee Forum 23 01-29-2016 06:49 PM
4.7L with intermittent miss-fire, told blown head gasket? pepelepeuu WJ Grand Cherokee Forum 13 11-04-2015 07:19 PM
Blown head gasket? reneveah WJ Grand Cherokee Forum 13 08-30-2011 08:13 PM
Possible blown head gasket or something else? hmmhoyhoy WJ Grand Cherokee Forum 2 04-20-2011 09:34 PM
Blown Head Gasket :( mrJ WJ Grand Cherokee Forum 28 11-13-2010 08:29 PM
