blew upper radiator hose and.... - JeepForum.com
post #1 of 7 Old 07-16-2013, 08:57 PM Thread Starter
lostbiker
my girls 99 wj limited blew the upper radiator hose and after a quick fix it started to nock and shake and bogged downed and died. checked the oil level and it was low and burnt so we put 4 quarts in and got a little better but still the same.... any suggestions? she has a rebuilt 5.2 with 45000 on it but 250XXXXX and the cluster
lostbiker is offline
post #2 of 7 Old 07-16-2013, 10:16 PM
pinky2252s
First of all, this is most likely about a ZJ right?
Second, I would be worrying about why it was 4 quarts low. If it was ran for a long time with only like 2 quarts in it, the engine might be toast.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #3 of 7 Old 07-16-2013, 11:32 PM
Jer-Bear
^^ Yep. Ruined cams and many other things that need friction.
/ 2002 WJ 4.7 H.O. / Flowmaster 50 SUV / Magnaflow Cats / Rocking that 2WD! /
Jer-Bear is offline
post #4 of 7 Old 07-17-2013, 12:07 AM
alfaitalia
Or rather don't need friction!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #5 of 7 Old 07-17-2013, 08:37 AM
Jer-Bear
Whoops lol
Jer-Bear is offline
post #6 of 7 Old 07-17-2013, 12:06 PM
rdkendrick
2003 WJ
Wow, 25,000,000 is even more than what I had. :-D
Sent from my iPad using Forum Runner
rdkendrick is offline
post #7 of 7 Old 07-19-2013, 03:31 AM
cykaaro
Either way, doesn't sound good.... .... where did the oil go? major leak that wasn't detected or seen? and how long was it run like that. Not good if its smelling burnt at all.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
