blend door motor? - JeepForum.com
post #1 of 4 Old 09-23-2012, 10:56 AM Thread Starter
dtrkyman
2013 WK
blend door motor?
so i cut the hole out behind the glove box and my blend doors were ok, my problem is the plastic gear that drives the door is cracked where it plugs into the blend door drive.
not sure if this is the proper termonology but the drive motor just keeps spinning due to the crack, can i get a replacement drive gear? or do i replace the whole motor?
Thanks
dtrkyman is offline
post #2 of 4 Old 09-23-2012, 02:28 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
It's usually referred to as an actuator, and yes you just replace the whole actuator at once. They are pretty cheap. The bad news is that the passenger side airflow motor is located deep in the dash, not accessible from the glove box hole. The one you are looking at controls the driver's side airflow.
~Richard
billzcat1 is offline
post #3 of 4 Old 09-23-2012, 05:41 PM Thread Starter
dtrkyman
2013 WK
yeah, everything thing else works fine, i was actually adjusting the blend door after i rigged the actuator and was trying to match the doors and then the actuator just stopped working completely? weird.
on a side note i was going to be able to calibrate the setting by using the other door as reference and setting the other to the same temp. setting.
cant believe the actuator quit, seems weird. any place to get the actuator?
dtrkyman is offline
post #4 of 4 Old 09-23-2012, 05:50 PM Thread Starter
dtrkyman
2013 WK
found one at 1a auto, 30 bucks. going to double check and make sure it is dead before ordering.
Thanks for the info.
dtrkyman is offline
Blend door issue but not door, actuator or control panel. What else could it be? TGMInd WJ Grand Cherokee Forum 37 12-19-2014 07:12 PM
hey, I need a drivers side blend door motor...? top1000nole WJ Grand Cherokee Forum 2 12-15-2011 09:10 AM
Blend door motor making clicking noise???? top1000nole WJ Grand Cherokee Forum 4 12-03-2011 02:00 PM
Blend door motor question? medflynurse WJ Grand Cherokee Forum 4 03-03-2011 06:26 AM
HVAC Issues: Blower Motor Wiring Harness/Connector, Blend Door, Recirc Door Problems mweb WJ Grand Cherokee Forum 2 01-30-2011 12:16 PM
