Blend door Actuators - JeepForum.com
post #1 of 5 Old 10-29-2011, 07:34 PM Thread Starter
alifted4x4
2009 JK Wrangler
I have searched and not come up with anything. How many blend door actuators does my jeep have? One person told me 2 and another said 3....
Thanks
2000 WJ 6 1/2" lift,IRO Coils, IRO Front ADJ Long Arms, Clayton Rear Long Arms, Bilstein 5100 Shocks, JKS Track bar, JKS Bar Pins, K & N FIPK, 265/75/16 Nitto Terra Grapplers, 1.5" Wheel Spacers, Addco Rear Sway Bar, IRO Rear Sway Bar Links, Flowmaster 40,2002 Cluster to be continued.....
alifted4x4 is offline
post #2 of 5 Old 10-30-2011, 04:34 PM
dutch724
It depends there is electronic ones and there is vacuume ones. I had mine apart last weekend and I counted 3 vacuum and one electronic.
dutch724 is offline
post #3 of 5 Old 10-30-2011, 05:18 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
Directly from the FSM...
BLEND DOOR ACTUATOR
DESCRIPTION
The blend door for all models is actuated by an
electric actuator, while the AZC system uses 2 separate
actuators to allow the driver and passenger to
select individual comfort levels.
To finish that statement: The manual system uses 1 actuator for the blend door and it is also electric but the manual system also uses 2 vacuum actuators to control the heat/defrost/floor doors (aka mode doors) and 1 vacuum actuator for the recirculation door.
The AZC system has a total of 4 electric actuators a) blend doors (2) b) mode doors and c) recirculation door.
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #4 of 5 Old 10-30-2011, 05:20 PM
ChiliPalmer
That would be correct. The electric one was the blend door and two of the vacuum actuators were on the drivers side of the HVAC sub assembly connected to a bunch of levers - those were the mode doors. And the third one was attached to the front passenger side of the sub assembly - that was the recirculation door.
Forum!
post #5 of 5 Old 10-30-2011, 05:22 PM Thread Starter
alifted4x4
2009 JK Wrangler
Thanks for the info!
Blend door issue but not door, actuator or control panel. What else could it be? TGMInd WJ Grand Cherokee Forum 37 12-19-2014 08:12 PM
Who has the best Blend Door Fix Kit? yrkoverland WJ Grand Cherokee Forum 42 11-28-2014 02:02 AM
Blend Door or Something Different? theskier74 WJ Grand Cherokee Forum 0 10-07-2011 07:18 AM
HVAC Issues: Blower Motor Wiring Harness/Connector, Blend Door, Recirc Door Problems mweb WJ Grand Cherokee Forum 2 01-30-2011 01:16 PM
WJ Door Lock Actuators... The_Scout WJ Grand Cherokee Forum 1 12-14-2010 05:14 PM
