BJ grease fittings rubbing on boot - JeepForum.com
post #1 of 7 Old 09-27-2013, 04:16 PM Thread Starter
reichhartkg
2003 WJ
I just put in new ball joints that I bought from Advance Auto. They choose the parts based on their computer.
All four joints have grease fittings. When I put the axles back in, I found that the grease fittings on the lower joints rub on the boots.
Anyone else run into this? Is there a way to work around it?
reichhartkg is offline
post #2 of 7 Old 09-27-2013, 04:57 PM
ZJPunk98
maybe installing an angled fitting instead of the straight one provided.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #3 of 7 Old 09-27-2013, 07:11 PM Thread Starter
reichhartkg
2003 WJ
The one provided is pretty short. Unless I can find one that sticks out at least an inch, I don't think it will help. There's not much room there.
Can I grease them, remove the nipple, and put in a set screw?
post #4 of 7 Old 09-27-2013, 08:47 PM
pinky2252s
Should be fine if you find one with the right threads.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #5 of 7 Old 09-27-2013, 09:08 PM
Jeeples
Jeeples's Avatar
There isn't enough room for a grease fitting there. Even if you found one that cleared the boot, how are you going to get a grease gun line in there to grease it?
My Moog ball joints came with a grease fitting and a plug.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #6 of 7 Old 09-27-2013, 09:52 PM
Merc1973
My Moogs were the same way. Just install the zerk, lube the ball joint and screw on the cap screw instead to clear the CV Boot.
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
post #7 of 7 Old 09-28-2013, 08:09 AM Thread Starter
reichhartkg
2003 WJ
I just got 1/4-28 set screws and hex cap screws. The cap screws are stainless, so I think I'm going to go with them, after trimming them down to length.
