-   WJ Grand Cherokee Forum (http://www.jeepforum.com/forum/f310/)
-   -   BJ grease fittings rubbing on boot (http://www.jeepforum.com/forum/f310/bj-grease-fittings-rubbing-boot-1629289/)
reichhartkg 09-27-2013 04:16 PM
I just put in new ball joints that I bought from Advance Auto. They choose the parts based on their computer.
All four joints have grease fittings. When I put the axles back in, I found that the grease fittings on the lower joints rub on the boots.
Anyone else run into this? Is there a way to work around it?
ZJPunk98 09-27-2013 04:57 PM
maybe installing an angled fitting instead of the straight one provided.
reichhartkg 09-27-2013 07:11 PM
The one provided is pretty short. Unless I can find one that sticks out at least an inch, I don't think it will help. There's not much room there.
Can I grease them, remove the nipple, and put in a set screw?
pinky2252s 09-27-2013 08:47 PM
Should be fine if you find one with the right threads.
Jeeples 09-27-2013 09:08 PM
There isn't enough room for a grease fitting there. Even if you found one that cleared the boot, how are you going to get a grease gun line in there to grease it?
My Moog ball joints came with a grease fitting and a plug.
Merc1973 09-27-2013 09:52 PM
My Moogs were the same way. Just install the zerk, lube the ball joint and screw on the cap screw instead to clear the CV Boot.
reichhartkg 09-28-2013 08:09 AM
I just got 1/4-28 set screws and hex cap screws. The cap screws are stainless, so I think I'm going to go with them, after trimming them down to length.
The time now is 06:58 AM.
