Bilstien 5100 on stock sagging WJ? - JeepForum.com
post #1 of 11 Old 03-27-2012, 01:32 PM Thread Starter
liquidxit2
Im wondering if I can put these on my worn out WJ to lessen the cost of installing the lift on my WJ.
I dont have the jacks, time or space to lift the jeep this time around. Between the newborn, school and work and the fact that I dont have the jacks to complete the job still Im fixing to get the lift put on. I figure I have already done the stabilizer and rear sway and I would limit it to springs, isos and the trackbar oh and the alignment + mount and balance 5 tires.
2002 Jeep Grand Cherokee Limited 4.7 low output quadradrive. 31in General Grabber AT2, OME HD, bilstein 5100, IRO sway links, addco rear sway. Kolak 3in exhaust with flowmaster SUV 50, magnaflow 3in cat, Custom K and N FIPK, modded airbox with ram air, Fastman 71mm Throttle body, PML RFE Deep pan, Autometer digital trans temp gauge, P.I.E. aux adapter, Infinity reference 3.5/6x9/6.5, 200w inverter, surco rack, front/rear/cargo husky liners.
liquidxit2 is offline
post #2 of 11 Old 03-27-2012, 01:47 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
What what?
You want to install lift shocks on a stock-height vehicle? Or you want to install shocks to counteract sagging springs? Are you lifting or not? You can get 5100s for stock height but they aren't suitable for a lift. (and the 4600s/HDs are preferred for stock height anyway). I'm a little confused.
~Richard
billzcat1 is offline
post #3 of 11 Old 03-27-2012, 02:25 PM
snobrdrkid07
WJ for Life
snobrdrkid07's Avatar
I have no idea what you are trying to do... That was confusing.
~ 04 WJ Overland 4.7 HO | Graphite Metallic | Quadra-Drive | Vari-Locks | Bilstein 4600ís | ADDCO Sway Bar | Powerstick Exhaust | RB1 | SuperChips Tuned | Much More to Come ~
~ 04 WJ Laredo 4.0 | Selec-Trac | MBP | OME HD 3" Lift | JKS TB | IRO Front LCA's and UCA's| Bilstein 5100's | Silent Armor 245/70/17's | Custom Front D.S. | Stillen Rotors/Pads | Tow Package w/ 3.73's | Moog HD Steering | Kenwood eXcelon HU | Alpine Speakers, Amps, and Subs | Bilstein SS | Auxiliary Transmission Cooler | Rock Lights | Light Bars | Lots of Cool Stuff ~
~ 05 Rubicon Unlimited 4.0 | 6-Speed | Dana 44's | Air Lockers | 4.11 Gears | Rock-Trac 241OR T-Case with 4:1 4-Low | OME HD Springs | Bilstein 5100ís | 245/75/16 Kevlar MT/R's on Moabs | Hansen Offroad Steel F/R Bumpers | Warn 9000xi Winch | Edge Performance Chip | Custom CAI | Hella Off-road Lights | Cobra 29 CB | Flash Lights | Recovery Gear | Fire Extinguisher ~
-Michael-
snobrdrkid07 is offline
post #4 of 11 Old 03-27-2012, 03:01 PM
robby65
2007 XK Commander
I think he wants to put the 5100s on a sagging/stock springs.
robby65 is offline
post #5 of 11 Old 03-27-2012, 03:08 PM
billzcat1
2003 WJ
But 5100s come in stock length, 2" lift, 3-4" lift and probably longer. We need more info. Stock length 5100s are going to be as unsuitable for a 2" lift as 2" lift 5100s will be on sagging stock springs.
~Richard
post #6 of 11 Old 03-28-2012, 05:58 AM Thread Starter
liquidxit2
Ugh....
I want to put the 5100s I got for my lift on before I take it up to get lifted to save on install costs....
post #7 of 11 Old 03-28-2012, 06:36 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Originally Posted by liquidxit2 View Post
Ugh....
how is blowing out 4 bilsteins going to save you money?
ratmonkey is offline
post #8 of 11 Old 03-28-2012, 07:11 AM
robby65
2007 XK Commander
That's a no. If you put lifted shocks on an already sagging stock spring you are asking for trouble.
And if you can get a couple of jack stands and a jack. Do the springs and shocks yourself.
then you only have to pay for the wheel alignment and tires,and save the $$$for the baby.
Congrats on the new addition to the family.safety first.
robby65 is offline
post #9 of 11 Old 03-28-2012, 07:57 AM Thread Starter
liquidxit2
Should have known better then to ask here. All I wanted was a yes or no about if the shocks had enough travel to handle worn out stock springs.
Congrats on the new edition to the family.safety first.
Thanks! Honestly I dont have a place to do the lift and would have to buy the jacks to do so since the floor jack I currently own is for cars and 1) doesnt go high enough and 2) isnt of enough capacity to safely lift the jeep.
Now if I didnt have a d44a I would just use my bottle jack and be done with it, but alas I would lift the front and not the back and I dont want to do half the job.
post #10 of 11 Old 03-28-2012, 10:07 AM
rdubbs
If you are going to have a shop install the springs for your lift then I don't think it will add a lot of cost to have them go ahead and do the shocks too. The shocks pretty much need to be removed anyways to get the springs out. I would ask the shop first to see what the cost difference would be if any.
Do the 5100s have enough travel to be put on the vehicle prior to the lift? Yeah probably but they will be compressed significantly. I wouldn't drive it for very long like that. Plus, you will have a difficult time installing the shocks without a jack since they are already extended fully.
Hope that is helpful. Good luck.
rdubbs is offline
post #11 of 11 Old 03-28-2012, 12:52 PM
billzcat1
2003 WJ
No. They will be too long. Just have them installed with the springs. It will not add any labor to the lift install as the shocks have to be removed to install the springs anyway.
~Richard
5100 Bilsteins for 3 inch IRO lift se_shlock WJ Grand Cherokee Forum 4 01-20-2012 11:34 PM
Install question about Bilstien front shocks on WJ jgentil WJ Grand Cherokee Forum 8 01-03-2012 02:09 PM
My 5100/5125 Bilstein Input. blazepsi WJ Grand Cherokee Forum 0 11-27-2011 05:56 AM
Bilstein 5100 questions guys BransJeep WJ Grand Cherokee Forum 3 03-31-2011 01:22 AM
MX-6 Vs. Bilstein 5100 Jason_alex WJ Grand Cherokee Forum 14 12-01-2010 01:42 AM
