Bilstein Hardware - JeepForum.com
post #1 of 25 Old 03-04-2013, 12:03 PM Thread Starter
fosterjd79
Bilstein Hardware
I remember reading somewhere (I think it was NarnWV that listed it) about buying upgraded or different hardware to install the bilsteins. Does anyone have that list? I can't seem to find it now.
fosterjd79 is offline
post #2 of 25 Old 03-04-2013, 12:15 PM
ChrisHager
Administrator
ChrisHager's Avatar
Originally Posted by billzcat1 View Post
If you purchase Bilstein shocks, you will need to provide some additional hardware. The OEM front shocks have studs welded into the bar pins where the mount to the axle. The Bilsteins just have holes. I tried to remove the studs but it was apparent after several heavy hammer blows that they were not pressed in (like I thought) but actually tacked in place.
Stock
Bilstein
The hardware you will need is 4 5/16-18 x 1-1/4" bolts Grade 5, 8 small 5/16" washers (grade 8), and 4 5/16" Grade 8 nylock nuts. All of these were available from Lowe's. I used Grade 5 bolts because the Grade 8 were not available in the right length, and honestly they will not be under that much strain anyway. The Bilstein shocks come with the appropriate bushings and hardware for the body-mount side, so no worries there.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is online now
post #3 of 25 Old 03-04-2013, 12:18 PM Thread Starter
fosterjd79
Thanks!
post #4 of 25 Old 03-04-2013, 03:07 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Thanks Chris! Seems like every time I get on here to answer a question, you've already quoted me from somewhere or another and answered it!
~Richard
billzcat1 is offline
post #5 of 25 Old 03-04-2013, 03:16 PM
busadave
my bilstein hd's came with new hardware
busadave is offline
post #6 of 25 Old 03-04-2013, 03:31 PM
ChrisHager
Administrator
ChrisHager's Avatar
Haha I remember well where that post was. I forgot to pick up the hardware ahead of time when I did my lift and had to pull it up on the fly!
Really? Nice.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #7 of 25 Old 03-04-2013, 04:47 PM
cuttysark
yeah mine did too
cuttysark is offline
post #8 of 25 Old 03-04-2013, 05:33 PM Thread Starter
fosterjd79
I guess I need to double check mine then. I haven't even opened the boxes yet.
post #9 of 25 Old 03-04-2013, 07:20 PM
vmo23
Same here. I ordered through Kolak, if that makes a difference.
vmo23 is offline
post #10 of 25 Old 03-04-2013, 07:23 PM
bradywgn71
bradywgn71's Avatar
I had to buy the bolts and nuts for my Bilstein 5100s from Kolak.
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline
post #11 of 25 Old 03-04-2013, 07:24 PM
vmo23
I have a feeling the 5100s come without bolts while the HD's come with them.
vmo23 is offline
post #12 of 25 Old 03-05-2013, 11:09 AM
JimmydaGreek
2015 JK Wrangler
Word.
2015 JK Unlimited Rubicon Loaded
2002 WJ Ltd 4x4 4.7L Upcountry/Selectrac
JimmydaGreek is offline
post #13 of 25 Old 06-19-2013, 10:17 PM
mnwildfan2k
Come ALIVE old thread....
I am going to be installing mine hopefully soon.
Anyone know what the rear hardware is?
Figure if were going o do 'em, might as well do them all with new hardware...
Bolts? Size? Sandwiched between washers?
mnwildfan2k is offline
post #14 of 25 Old 06-20-2013, 02:36 AM
devinci
I would imagine that the stock bolts you take out to remove the old shocks would work just fine.
3" IRO, DT 8000s, 31x10.5 Duratracs
devinci is offline
post #15 of 25 Old 06-20-2013, 03:32 AM
ADragg
2003 WJ
I wouldn't bother, the stock bolts are just fine. I just installed Bilstein 5100's today (used Bilzcat's write-up to purchase the front lower shock hardware and as a general guide for the lift. However, the stock bolts on mine were big, heavy duty bolts that worked fine. I wouldn't both replacing them unless they're rusted as hell or something.
However, the one problem I did have (and still kind of have since I'm still finishing the last bits of the lift tomorrow), is that the upper front shock mounts just spin when you take the old shocks off and when you put the new Bilsteins in. The stock shock had a 6mm hex at the top of that post, but you have to hold that with a socket and then use a box-end wrench to actually loosen the shock bolt to get it off. PITA, because there's very little room to work the wrench in there.
Now I'm having the same issue with installing the Bilstein's. Even with the vehicle back on the ground, the shaft just spins (obviously it would, because it's a round chrome shaft with nothing to stop it accept the post at the top, which is an allen type, instead of a hex like the stock one). I can put an allen wrench into the top of the post to hold it still, but I still have to tighten the main bolt and again, have to use a regular wrench, which is HARD and takes forever. Plus, even after it's tight, I can't finish tightening it with a socket as it continues to spin. I can't even tell if I've got the torque spec right...
Such a PITA. Why does no one have this problem? I people never seem to mention trouble with the shaft spinning when trying to remove the shock, nor when installing new ones.
ADragg is offline
