BGF TA KO vs General Grabber AT2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > BGF TA KO vs General Grabber AT2
New Knuckles Skid Plate at JeepHutIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker Purcha
Unread 02-03-2012, 09:03 PM   #1
WeThePeople408
Wj BGF TA KO vs General Grabber AT2
I'm running a 3" IRO lift with an adj trackbar and I recently installed a set of BFG TA KO's on my 04 WJ (265/70/17's) through America's Tire for about 1k and 0% interest 12mo, and I really like the tires... but I'm having second thoughts. I have 30 days to return the tires and swap them for another kind and am debating on getting the General Grabber AT2's at a slightly smaller size (265/65/17). As I understand besides the initial cost savings, the gas savings will be minimal, and my minor rubbing issue might be resolved... but is it worth swapping them? Thoughts? Or just trim and rest easy...
My Jeep pics:
http://s1068.photobucket.com/albums/...8/Jeep%20Pics/
WeThePeople408 is offline   Reply With Quote
Unread 02-03-2012, 11:31 PM   #2
Planetcat
I've had both. If you ignore the cost factor, I would stay with the BFG's. They are a proven all-terrain tire. I just bought a set of Grabber AT2's for the WJ (265/70R16). The tread design is very similar and I'm sure they'll wear same or better than the BFG's, but the Grabber sidewalls are flimsy (I think they're Load rating C). I've had BFG A/T's on every truck and SUV I've owned and love the tires, but in all honesty, they've priced themselves way out of the market for an A/T. I paid $132 ea for the Grabbers and the same tire in BFG A/T would have been over $200.
2004 WJ 4.7L, 1959 CJ-5, 1990 XJ Limited, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline   Reply With Quote
Unread 02-04-2012, 02:27 PM   #3
leadsled jeep
You can buy the AT2 in two ply or four ply as I recall. It's not fair to rate a four ply BFG with a two ply AT2. Load rating on both four ply versio s should be similar.
Chris
'02 Overland 130k+ miles. 245-70-17 GG AT2's. BDS 2" lift, Bilstein 5100's, JKS QDs. Addco Swaybars F/R. Stillen Front Rotors/ Pads. TRE's, BJ's, wheel bearings. 100% Amsoil. I like my rifles like my coffee, hot, black and continually refilled.
leadsled jeep is offline   Reply With Quote
Unread 02-04-2012, 03:55 PM   #4
hyperlightboard
TAKO's there's a reason why the tires have not changed tread patterns/designs in a long time. they are a proven tire
Dink and Flicka
hyperlightboard is offline   Reply With Quote
Unread 02-04-2012, 04:57 PM   #5
amremt408
Wethepeople408,
Are you in norcal? I'm in san jose and just installed the OME lift on my WJ. I was planning on doing the BFG AT at the same size, because I want the load rating C. Is the rubbing really bad? Got any pictures?
5.9 ZJ... 4.5" Rubicon Express short arms. Bridgetone REVO 2's... 265/75/16.
2004 WJ... OME HD coils, Bilsteins shocks, JKS adj track bar, MOOG SS, ADDCO rear sway bar with ext., Bridgestone REVO 265/70/17.
amremt408 is offline   Reply With Quote
Unread 02-04-2012, 05:13 PM   #6
Jaketit
Jaketit's Avatar
Yea I would love a set of BFG all terrains but 255 75 R17 are on national backorder for who knows how long Going with the goodyear mtrs
Jaketit is offline   Reply With Quote
Unread 02-04-2012, 09:33 PM   #7
WeThePeople408
Thanks guys, your replys are appreciated.
Unread 02-04-2012, 09:38 PM   #8
WeThePeople408
Originally Posted by amremt408 View Post
Wethepeople408,
Hey amremt408, ya I'm in SJ. I posted a link to my photobucket in the OP. I'd suggest getting them at Americas Tires on Brokaw, theyre flexible on pricing and have great service. Ask for Dave or Johnathan. They even hooked it up with a free spare of the same size (used and worn but same diameter) to match, until I decide on buying a matching 5th tire. Load rating C is great, anything heavier would be a rough ride and overkill. Jeep on!
Unread 02-05-2012, 12:10 AM   #9
amremt408
Sweet! I'll check America's Tires out. I'm currently on my phone and couldn't get to that link... I'll check it when I get home...
