Beware- Timken Bearing assemblies - JeepForum.com
post #1 of 25 Old 12-20-2011, 11:37 AM Thread Starter
askoop
Driver side front wheel bearing needed replaced, so I had AZ order me a Timken as opposed to using their Duralast brand which I assume are made in China. Last I knew Timken were made in the USA too, which I like a lot more. Figured $20 more for made in the USA and a better part was worth it.
Got everything apart today at lunch and ready to go back together. First thing I noticed on the Timken bearing assembly is that it is now stamped "Slovakia", NOT USA. Second, they are not threaded correctly and the stock bolts will not fit the new Timken assembly. I wire brushed the threads to clean them up before trying too. I read of someone else having this problem too, but was hoping that was a fluke.
Now I am stuck using the duralast brand and I guess hoping it lasts. I am going out of town this Friday an cannot wait to order some from rock auto or 1A Auto.
-Adam
His: 2000 WJ, 2.5" BB, mx-6 shocks, Rancho 5000 Steering Stabilizer, 245/75/16 MTRs, 1" addco rear sway bar, 9005 fog upgrade
Hers: 03 KJ, 5-speed, 245/70/16 General HTS
WTB: 1 Timberline wheel or a set of JK steelies
askoop is offline
post #2 of 25 Old 12-20-2011, 11:42 AM
kastner03
i just did both sides on my jeep last week with timkens and the bolts fit just fine, maybe u got a bad one?
kastner03 is offline
post #3 of 25 Old 12-20-2011, 11:55 AM
skain8
skain8's Avatar
Your AZ sales associated ordered the wrong hub/bearing. I have timkens with no fitment issues.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #4 of 25 Old 12-20-2011, 12:04 PM
seu83
Same here I did both front bearings back in July with timkens with no issues.
seu83 is offline
post #5 of 25 Old 12-20-2011, 04:09 PM
Bphase
I just did my drivers side with timkin bearings last week and got new bolts from the Stealer and everything went smooth. So IDK?
Bphase is offline
post #6 of 25 Old 12-20-2011, 04:39 PM
MeanGreenZJ
Slovakia has been building things far longer then the USA, so how bad can it be?
MeanGreenZJ is offline
post #7 of 25 Old 12-20-2011, 04:52 PM
nickblack
No trouble with my recently installed Timken's.
nickblack is offline
post #8 of 25 Old 12-20-2011, 08:11 PM
radoboy
Installed my Timken fronts a few weeks back without issue.
Brien
1999 WJ 4.7 QD
2000 Audi S4, 2013 Audi A3 TDI, 1990 Corrado 16vT, 1993 Corrado VR6
radoboy is offline
post #9 of 25 Old 12-20-2011, 08:27 PM
TJSWJ
I did 2 New timkens about a month or so ago as well, and had no issue. I also think they gave you the wrong bearing
TJSWJ is offline
post #10 of 25 Old 12-20-2011, 09:51 PM
WiCkeDuDe
WiCkeDuDe's Avatar
I have literally done maybe a dozen timken WJ front bearings over the last 1.5 years and never had an issue with any. Sounds like you got the wrong bearing or the wrong bearing put in the box.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #11 of 25 Old 12-20-2011, 10:13 PM
csouers
X2 on the wrong hub. Post up what part number(s) you were given.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #12 of 25 Old 12-21-2011, 05:46 AM
WJ04
I remember reading somewhere that some companies and shops were using noname brands and putting a timken sticker on them and selling them as timkens. Make sure it comes in a real timken box and varify the part number.
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
Some of my videos:
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline
post #13 of 25 Old 12-21-2011, 06:04 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
So has China, just like the majority of the rest of the world considering how young the USA is.
Learn some history and average labor rates in Slovakia and China, then see if you wish to move there yourself to make wheel bearings.....
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #14 of 25 Old 12-21-2011, 09:41 AM
MeanGreenZJ
I know my history just fine. History shows that China is full of US companies and contractors wanting to make crap as cheap as possible. China delivers exactly what the US wants, cheap crap, cheaply made.
Now if you were to pull your head out of the sand, you would see that I don't need to make cheap bearings in Slovakia or China, I can do it right in the USA, since it's looking more like China everyday. ....
Martin
post #15 of 25 Old 12-21-2011, 11:52 AM
leftlanetruckin
XJ on 37's
I see the point precisely mate. But attempting to buy "made in the USA" anymore is damn near impossible at times. My reference was to the fact that there is little difference between the countries mentioned, cheap labor wise. Slovakia is a cheap labor country, thus the fact they have made stuff for a long time is, well, irrelevant IMHO
It is a terrible shame that "US companies" relocate plants to 3rd world #%$holes to save a few bucks. Funny thing is though, I never see the retail price of the foreign made junk go down....
If we ever get a government with a pair of balls, introducing an extra tax on the import of such items may slow it down a little IMO.
Martin
BEWARE: spark plug disaster jptaylor2 WJ Grand Cherokee Forum 13 08-17-2011 04:06 AM
Again With the Wheel Bearing? RootJ WJ Grand Cherokee Forum 2 10-04-2010 06:43 AM
Possible Hub Bearing ledfoot02 WJ Grand Cherokee Forum 2 08-26-2010 09:29 AM
Axle Shafts or Hub Assemblies? What to replace first kadetklapp WJ Grand Cherokee Forum 5 08-25-2010 03:00 PM
