Best Thing To Do About Wet Carpets? (passenger side) - JeepForum.com
post #1 of 22 Old 03-30-2010, 07:00 PM Thread Starter
steveridesli
Best Thing To Do About Wet Carpets? (passenger side) Also, Is It Bad?
My passenger side got a little flooded tonight when i went wheeling. Not much, less than half a inch in the back and front. only passenger side. whats the best thing i can do?
i dont really wanna rip up my carpet. im shop vaccing it now.
what else should i do?
also. I got stuck in the huge puddle. i had to get pulled out because my engine stalled and would not start back up.
So i get pulled out, and my friends friend says my engine is hydro locked, and with my lack of knowledge of engines, just listened to whatever he said. he said dont try starting it again, i didnt. We have another kid come to pull me through the rest of the trail, and when he gets there, he asks me to crank it. i do, and it starts up, a little rough, but it started. he said there was just alot of water in my muffler or something, and i should just rev it for a few minutes and ill be good. I did, and i got home fine. Everything seems good, but im not sure. Is there anything i need to do? Anything that might be screwed up?
steveridesli is offline
post #2 of 22 Old 03-30-2010, 07:03 PM
bigbill888
Um--shop vac? Ah--leave windows open tomorrow if it's dry out??
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #3 of 22 Old 03-30-2010, 07:04 PM
ZJ5point2GCL
do you have a de-humidafyer?
its hard to get water out, because of the heavy backing soaks up water,
but i have allot of experience trying to dry out jeeps, and putting a de-humidafyer in it for 12 hours works really well, but you do have to pull the carpet up near the edges for airflow.
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #4 of 22 Old 03-30-2010, 07:10 PM
CrazyIvan888
Wear boots when you drive.
Seriously though,
Is it relatively clean water or is it the smelly swap stuff? If it's clean, just shop-vac it as much as you can and run the blower on the floor setting whenever you drive until it's dry. As mentioned, a de-humidifier is an excellent idea if you have one.
If it's the smelly, muddy crap, I would take it somewhere and have it shampoo'ed. We won't tell.
Jeep: Every adventure is a repair, every repair is an adventure!
CrazyIvan888 is offline
post #5 of 22 Old 03-30-2010, 07:33 PM
comptiger5000
A strong shop vac will get the water out pretty well, then just drive with the A/C on for dehumidifying (use the feet vents) for a day or 2, and park with the windows partly open if the weather's nice.
comptiger5000 is offline
post #6 of 22 Old 03-30-2010, 08:00 PM
JesseOR
Go to a store(wally world, Lowes, Homedepot) and get a product called Dri-Z-Air. It comes in a little bag and its little pellets that soak up water like crazy.
DON'T PUT THE PELLETS ON THE CARPET!!!
They sell a little holder for them.
-Jesse-
GO DUCKS!
www.facebook.com/jesse.whitehargrove
JesseOR is offline
post #7 of 22 Old 03-30-2010, 08:11 PM Thread Starter
steveridesli
i pulled up the carpet on the sides in the front, got under and cleaned all the water under the front floor matt pretty good. now its just what ever is soaked into the carpet and that **** thats on the back of it. As for the back seats, i couldnt really get the carpet up without getting it in a posoition that looked like it would mess it up. ill try that dri-z-air stuff 2m when home depot opens, and i will try to find my dehumidifier
post #8 of 22 Old 03-30-2010, 10:33 PM Thread Starter
steveridesli
made an edit
post #9 of 22 Old 03-30-2010, 11:33 PM
flyboy14295
So everyone answered your first question. On to the second part. Do you know roughly how deep the water was? Did it come over your hood? Did you stop and sit in it for more than 10-15 seconds(if it was deep)?
Whoever said it was just water in your muffler, don't listen to him, that wouldn't affect your engine. The muffler is a sealed unit from your exhaust headers. The only way water got in is if there is a crack or it came in the exhaust pipe(which is impossible while running) If you did hydro-lock it, you could have bent a rod, blown a piston seal.
For reference for next time. If you think you hydro-locked it, pull ALL of your spark plugs, crank the engine and whatever water was in the cylinders should mostly come out. Insert plugs and crank 'er up.
WJ. 4.Slow I6. The Underdog
2" Teraflex BB, 265/70R16 BFGoodrich TA KO's, JKS Adjustable Track Bar, JKS HD Tie Rod, Rusty's Tow Hooks, Block Heater, CB
New York City EMS
Originally Posted by LoneJeeper View Post
I came into this world via broken rubber, i'm not going out the same way.
flyboy14295 is offline
post #10 of 22 Old 03-30-2010, 11:43 PM Thread Starter
steveridesli
we were gonna take out the plugs and do that but we had no tools. it wasnt a crazy trail that we were too sure about going to, just a spur of the moment thing. and the water came over the hood while i was driving through it, but came just above the gray trim while i was stopped in it for the, about 5 minutes, it took to use a hand winch to pull me close enough to my friends truck to pull me out. Video coming soon! lol.
what are the symptoms of a broken seal or bent rod? My gas mileage seemed to be a little better, maybe im just crazy. She ran fine.
post #11 of 22 Old 03-30-2010, 11:52 PM
ZJ5point2GCL
how did it stall? hard to explain what i mean, but when i sunk my jeep, i thought i might of hydro locked it, because i would try to start it and it would just make a loud clunk for a second then die, so i pulled the plugs and there was no water in, but it was just the submerged computer messing with things, but i think it would be fairly obvious if you did some damage, it would be loud and probably misfiring if it was a bent rod or at least smoke allot if you messed up a piston ring
post #12 of 22 Old 03-30-2010, 11:58 PM Thread Starter
steveridesli
nah everything seemed to be running good. I was just trying to make it through the puddle, and the engine stopped. i shut it off, tried to start it, it was cranking but not turning over. my friends told me to stop, it was gonna make it worse. so i did, they pulled me out of the puddle, my friend took out my air filter, saw it was soaked, and then said itd be best if i got towed out to where we had tools and i took out the spark plugs. when the guy who was gonna pull me out of the trail got there, he asked me to crank it so he can hear. and it started right up. for all i know, it wouldve started the second i got pulled out of the water, but they said dont try.
post #13 of 22 Old 03-31-2010, 12:07 AM
WJChris
WJChris's Avatar
for the carpet-
try keeping the carpet slightly lifted and allow the air to get UNDER it too. Keep windows open as much as possible to let the moisture evaporate.
Best option would be to let the sun shine on it (open the door) and/or let a fan run over/under the carpet for a while. Do not put any mats over the carpet for a few weeks.
WJChris is offline
post #14 of 22 Old 03-31-2010, 12:13 AM Thread Starter
steveridesli
Originally Posted by WJChris View Post
for the carpet-
alright, im gonna go stick something under the carpeting now. i cant get under the back carpeting though
post #15 of 22 Old 03-31-2010, 12:14 AM
ZJ5point2GCL
if it was hydrolocked at that stage it would't start so easily, so your safe there, depending what kind of air filter you have, if its a factory paper one or a k7n type cone. the filter could of just got wet and possibly plugged, i had my k&n cone and after muddy wheeling it got covered, and they next morning after driving home in the rain, it had dried solid, it wouldn't start, just crank, so i took a look under the hood, expecting an IAC issue, and the filter just couldnt let air past, popped the filter off, and it fired up right away
Why in the world is the passenger side hot and the driverís side cool??? red5ive WJ Grand Cherokee Forum 4 03-10-2010 10:54 AM
Passenger side air is warm. HurriJeff WK Grand Cherokee & XK Commander Forum 14 11-12-2009 08:14 PM
99 Grand Cherokee Ltd Heat on passenger side cold on Drivers side. WHATS WRONG?? nosguy ZJ Grand Cherokee Forum 9 12-30-2007 09:15 AM
Passenger side mirror chrisstromberg ZJ Grand Cherokee Forum 3 06-05-2007 01:00 PM
No heat on passenger side hanxtr ZJ Grand Cherokee Forum 5 05-09-2006 05:55 PM
