Best Replacement Head Gasket - JeepForum.com
post #1 of 9 Old 10-29-2011, 10:48 AM Thread Starter
JeepAMG
I am going to be replacing my head gaskets shortly and wanted your guys opinion for the best replacement. Most people I heard either did stock Mopar or Cometic gaskets. From my prior experiences which is 2 times, I will never get Cometic again.
I heard from a few friends of mine that VICTOR REINZ gaskets are very good and they have a Multi-Layered Steel design. After doing some research, I honestly have nothing bad to say about Victor Reinz.
Also DNJ ENGINE COMPONENTS is up for question.
What is your opinion?
Stock Mopar?
Cometic?
Victor Reinz?
DNJ?
JeepAMG is offline
post #2 of 9 Old 10-29-2011, 11:06 AM
Cirruslydakota
Mopar or Fel-pro. Chances are the Mopar one is probably made by Fel-pro anyway.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #3 of 9 Old 10-31-2011, 04:33 AM
kfxnando
hopping I don't need baskets for a long time
however when that day comes will seriously consider, copper baskets, they are reusable and way more forgiving then multiplayer baskets
however VICTOR REINZ are known worle wide for their quality, although I have seen one go bad, where it physically broke and the water was coming out between the head and block
http://s538.photobucket.com/user/kfxnando/library/?sort=3&page=1
kfxnando is offline
post #4 of 9 Old 10-31-2011, 06:18 AM
seu83
I've always used fel pro and never had a problem.
seu83 is offline
post #5 of 9 Old 10-31-2011, 07:00 AM
WiCkeDuDe
WiCkeDuDe's Avatar
Pretty sure this is true. I had them side by side and they seemed the same. I went with Fel pro as they were cheaper. Never had an issue on the WJ or any other fel pro head gasket I have ever used.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #6 of 9 Old 10-31-2011, 07:42 AM
ChrisHager
Administrator
ChrisHager's Avatar
I installed Fel-Pro on mine. So far so good...
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #7 of 9 Old 11-03-2011, 01:10 PM Thread Starter
JeepAMG
Thnx for the info guess I will decide this weekend felpro or Viktor rienz and place the order
JeepAMG is offline
post #8 of 9 Old 11-03-2011, 03:06 PM
epGTO
I used the VICTOR REINZ gasket set when I replace my head gasket and supporting gaskets (valve cover gasket, valve seals, etc...). I chose it because it looked just like the OE ones I removed (same colors and textures) and it was a lot cheaper than the Felpro set. I'm usually cautious about getting cheaper parts because the quality is usually bad but since they looked just like the OE and the Felpro didn't, I took the gamble. I have ~5K miles on the new gaskets and everything is still good.
epGTO is offline
post #9 of 9 Old 11-03-2011, 06:01 PM
Cirruslydakota
Just bought a new Fel-Pro gasket for my valve cover. It has the Chrysler part number stamped on it so I'm 100% sure they are the oem gasket supplier.
Bear - 99 WJ Laredo
4.7L V8 Head Gasket Replacement jaytee1456 WJ Grand Cherokee Forum 11 07-22-2015 11:46 AM
4.0l head gasket replacement procedure grancherkee WJ Grand Cherokee Forum 1 04-11-2011 10:47 AM
4.7 h.o. head gasket adamcorey WJ Grand Cherokee Forum 2 02-05-2011 08:42 PM
4.7L head gasket C-note WJ Grand Cherokee Forum 7 01-08-2011 08:42 AM
4.7 head gasket howie123y WJ Grand Cherokee Forum 0 07-14-2010 03:53 PM
