best place to get swaybar link bolt? - JeepForum.com
post #1 of 6 Old 07-14-2013, 09:47 PM Thread Starter
KDR83
Put in my BB along with Bilsteins today, only issue I had was when I was torquing the bolt on the rear swaybar link it snapped. Can I just go to lowes or home depot and grab a comparable sized Grade 8 bolt or do I need to go to the dealer? Anyone know what size the bolt is? Don't think I want the 5 zipties as a permanent solution
KDR83 is offline
post #2 of 6 Old 07-14-2013, 09:58 PM
lance-tek
I think Lowes grade 8 would be fine. Sway bar isn't weight bearing at all. The zip ties might even be enough lol
I will eagerly accept any advice or help I can get. | Built Not Bought # 736
lance-tek is offline
post #3 of 6 Old 07-14-2013, 11:44 PM
alfaitalia
Well its load bearing enough for me to have seen the top mounts be pulled from the frame few times! Under quite a bit of force under fastIsh cornerIng. Don't think the ties will last that long!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #4 of 6 Old 07-15-2013, 08:38 AM
lance-tek
Agreed, it is load bearing; just not weight bearing. So, if one is mindful to take it easy the zip ties *might* last :P
Still though grade 8 bolts are appropriate.
post #5 of 6 Old 07-15-2013, 08:44 AM
SirCussFreq
What's the proper size? I lost one myself last weekend, have 4 heavy duty zipties holding that side up now. I tried to pick up a 1/2" bolt but it was just a bit too big. Plus the nut is still attached on the other side, so the proper stock bolt size would really be ideal. Looks like it's maybe 10 or 11mm?
SirCussFreq is offline
post #6 of 6 Old 07-15-2013, 02:31 PM
leadsled jeep
The stock bolt has a special shoulder on it. I doubt grade 8 would work.
Take out your non broken bolt and you'll see what I mean.
Order from Kolak if you can wait. Otherwise.... Dealer only item.
Chris
'02 Overland 190k+ miles. 2.5" lift w/springs. All Control Arms upgraded, dual Addco sways.
leadsled jeep is offline
