best oil and filter for my 2002 2.7crd ? - JeepForum.com
post #1 of 7 Old 04-08-2013, 09:26 AM Thread Starter
limyjeepster
Question best oil and filter for my 2002 2.7crd ?
Hi All after a little research Mobil seem to advise 0-40 Mobil 1 for the Jeep 2.7CRD any thoughts from you high milers out there on oil brands ? it very rearley gets above 20c hear in the uk and has been almost sub zero for most of the last 5 months also K&N Air filter Oil Filter or OEM... just want to fit the best... all advice apreciated
regards to all from the UK
limyjeepster is offline
post #2 of 7 Old 04-08-2013, 10:24 AM
KayCeeJeep
Isn't that a diesel? We don't have them here in the US. Mobil 1 0w40 is fantastic oil but it is not diesel rated as far as I know. IMO you need to stick with diesel oil. There are some Jeep guys from the UK on here hopefully they will chime in.
K&N air filters let a lot of contamination in, not a good idea for a diesel either IMO they run dirty enough as it is. Actually the Mopar air filter is great if you can find it, otherwise a good aftermarket would be a better choice.
KayCeeJeep is offline
post #3 of 7 Old 04-08-2013, 11:03 AM Thread Starter
limyjeepster
according to mobil the corect oil for the 2.7 is the Mobil 1™ Turbo Diesel 0W-40 i just shortend it to 0 - 40 was just cheking to see if any other users agree as for air filter thanks for the info... just replaced rear disks and pads to find the rear calipers keep sticking looks like new calipers are on order next.... thanks for the input a few more opinions would be appreciated.. regards mark
post #4 of 7 Old 04-08-2013, 11:13 AM
alfaitalia
Paper air filter...does not seem to matter which in my experience! I use the paper ones with the layer of foam for a bit of extra life to the the filter. Any fully synth oil of the right grade....whatever I can get a deal on but not shops home brew!
Just rebuild the calipers. Just did all four of mine...dead easy. Took about 1/2 an hour per corner. My seals were good...reused them... but the bores had a layer of build up stopping the piston sliding easily. No cost except your time and 1/2 a litre of brake fluid or so.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #5 of 7 Old 04-08-2013, 03:35 PM Thread Starter
limyjeepster
nice 1 alfa i get ver good discount on mobil 1 so will go with the Mobil 1™ Turbo Diesel 0W-40 also gona drop the gearbox sump and change fluid n filter thought it may be a good idea to do the diffs as well cant see a drain bung so i imagine its seringe it out and fill till it trickles out and i also see a mention of friction modifier how do i know which one is correct for the 2.7crd ?... ok hear is a newby question acording to data i also have a transfer case not sure where this is ? imagine its after the gearbox.. i whish there was a paper manuel for the 2.7 crd... so much to learn... ps thax for the advice about moding the bulk head has made doing the injectors a breaze... thnx again..
post #6 of 7 Old 04-08-2013, 04:30 PM
alfaitalia
Ok . You can syringe the oil out of the difs but you won't get any metal particles out that way or be able to check its condition. Take the covers off clean it out and rtv the covers back on. Use quality dif oil.
If near your gear selector levers it says QuadradrIve (unlikely) then that what you have and you need friction modifier in the axles only. If it says Quadratrac (most likely) then you don't need fm. Either way the transfer case is the same one and needs the factory spec fluid ONLY...mopar if you can find it (discontinued in the UK) Petronas other wise.
You are correct about the tc location.
If you hunt back to one of my early threads you will find a link to pdf versions of the CRD parts manual and factory service manual. Download it and just print pages as you need them. Would put link on here but can't do it on my phone. Cheers!
EDIT; Found the Parts and service manual link:
http://www.jeepforum.com/forum/f310/...ested-1308213/
Sent from my HTC Wildfire using JeepForum
post #7 of 7 Old 05-23-2013, 03:25 PM
HARRISON111
You know your stuff alf
HARRISON111 is offline
