Best ball joints? - JeepForum.com
post #1 of 6 Old 07-19-2012, 03:43 PM Thread Starter
BolderGuy
2013 WK
Wj Best ball joints?
I leaning toward Moogs - RockAuto has em for cheaper than Moog's website. I know they cost a little more but at 120k, I'm figuring if I use the Moogs I'll never have to worry about ball joints again.
One issue - they have 2 sets for upper and lower - 2 sets are non-adjustable, the other 2 are adjustable for caster and chamber.
With a 4" lift, which set would be better?
http://www.moog-suspension-parts.com....asp?cat=10922
BolderGuy is offline
post #2 of 6 Old 07-19-2012, 06:27 PM
AndyL
typically, you cant go wrong with moog stuff. does your alignment support the need caster modified ball joints? At 4" of lift, might not be a bad idea to get you back to spec, or least closer. Factory Dana/Spicer is good stuff too.
AndyL is offline
post #3 of 6 Old 07-19-2012, 06:39 PM
fosterjd79
I just put in the moogs but have only put about 5 miles on them so I can't comment on quality.
fosterjd79 is offline
post #4 of 6 Old 07-19-2012, 08:54 PM
the88thpianoman
2003 WJ
I'm not speaking from firsthand experience, but I've seen a lot of reports of Moog parts that are actually TRW and other brands with Moog stickers stuck in Moog boxes. It's worth at least peeling up the sticker on the next Moog part you buy and seeing if there's anything else underneath it.
Personally, I've been running NAPA premium ball joints which have been going strong for at least 60 or 70k miles. NAPA premium was the ONLY brand I could find anywhere with adjustable uppers instead of only adjustable lowers. Depending on which way the camber needs to be adjusted, you may require those. My situation was that the top of the tires were leaning inwards. The lower adjustable ball joints would have brought the bottom of the tire into alignment with the top, but caused too little clearance between the knuckle and the axle. I had to find the adjustable uppers to push the top of the tires outwards into alignment with the lower fixed joints.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #5 of 6 Old 07-19-2012, 09:22 PM
AndyL
Youre right, no one make everything. They all source from each other to have a complete line and lots o' SKUs. Dana/Spicer parts for a Dana axle is a sure bet, Moog or TRW whichever you actually get will likely be okay.
The original Dana joints lasted how many miles? How much you gonna save? The install time is the same.
AndyL is offline
post #6 of 6 Old 07-19-2012, 09:37 PM
AndyL
I've installed Specialty Products over the years, they have solutions for most common suspension/alignment problems. Do you NEED adjustable ball joints?
http://www.spc-tv.com/
On page 54 of their online catalog, #23510 thru 23540 are for upper positions. You need to know your needs, they supply via undercar W/D's for professional shops.
http://spcalignment.com/specprod/digitalcatalog/#/54/
Enjoy.
AndyL is offline
Ball Joints Shilman23 WJ Grand Cherokee Forum 5 07-13-2011 07:52 PM
Ball Joints crazyeyes WJ Grand Cherokee Forum 2 05-07-2011 05:28 AM
98 and 99 wj ball joints evader68 WJ Grand Cherokee Forum 6 04-22-2011 05:45 PM
ball joints kastner03 WJ Grand Cherokee Forum 0 03-15-2011 08:44 PM
Ball/CV Joints Quantum WJ Grand Cherokee Forum 12 12-25-2010 04:46 PM
