Bent pushrod? 2004 4.7L WJ - Page 2 - JeepForum.com
post #16 of 20 Old 11-24-2013, 10:12 PM
doorjamm
Originally Posted by three_jeeps
well ya, ya did....thread envy???
Haha woops just a little jealousy
doorjamm is offline
post #17 of 20 Old 11-24-2013, 10:31 PM
99_wj_QD
Originally Posted by car5car View Post
It usually takes about 1 min to fix lifter tick and I did it probably 50 times.
Really? How did you manage that with hydraulic, non adjustable lifters?
99_wj_QD is offline
post #18 of 20 Old 11-24-2013, 11:23 PM
mycreativename
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #19 of 20 Old 11-25-2013, 04:03 AM
Darnice
Originally Posted by 86cj74.2L View Post
Their is a air pump operated by vacuum that makes a pretty loud tapping sound. Its mounted on the drivers fender. You can't miss it.
Put your hand on it and you will be able to feel the tap. If its in time with the engine noise forget about it. That's what I did.
On a side note my work partner has a old ford ranger. When you tell him his engine is making noise. He says its made that same noise for 20 years. When it stops he will worry.
This is an 04, no air pump on the fender, it was relocated to the back beside the gas tank.
Darnice is offline
post #20 of 20 Old 11-25-2013, 04:13 AM
86cj74.2L
86cj74.2L's Avatar
My 04 Laredo has it on the inner fender and so does my mother in laws 04 limited.
Its mounted near the top of the drivers inner fender. Can't miss it. It's got two vacuum diaphragms and hard plastic lines and a funky S shaped mount to try and isolate the bumping noise. (A recall for that noise resulted in the S shaped mount bracked to try and isolate the noise) I'd take a picture but its at mother in laws hooked to the battery tender. I'll be there to run the dogs this afternoon and try and remember to snap a picture.
86cj74.2L is offline
