Originally Posted by MiCrOz
Does anyone know if the bushing(s) in the IRO adj. track bar are worth replacing, or are they fine as is?
Good question. An easy way to tell (aside from watching the bushings while someone turns the wheels back and forth) would be to see if you can squeeze the bushings by hand. If you can squeeze them at all, they probably aren't too far off from the JKS bushings and will almost for sure allow play on your vehicle. The KOR bushings are virtually as hard as a rock and you can't squeeze them by hand to where they change shape at all.
