BDS coil spring spacer for zj fit wj? - JeepForum.com
post #1 of 2 Old 05-19-2011, 09:02 AM Thread Starter
Jason_alex
Hey guys,
Just look at the instructions for the 3/4" BDS coil spring spacer for the zj and in the instructions it hat zj, wj, xj and wj.
Will the 3/4" spacers fit a wj the tec support said no but im just wondering if they will, they however do have a notch cut out of them though.
http://bds-suspension.com/instructio...201-174101.pdf
Thanks,
Jason
2001 Jeep Grand Cherokee Laredo 4.0L Selec-Trac 2.5" ROR lift
1977 Trans Am 400 bored 40 over new paint new sub-frame.
Jason_alex is offline
post #2 of 2 Old 05-19-2011, 09:30 AM
overlandchris
No they will not, the diameter of the zj coil springs is less then that of the wj and the upper coil support is narrower on he zj which means the spacer wil not fit onto the larger wj support.
4.7 V8 H.O. The Chevy 302 of Jeep Engines. Roar...
2004 Grand Cherokee Overland, Midnight Blue Pearl.
Rusty's 2" Budget boost, It Goes fast
Project "Shamrock": 96 Cherokee country, black, I6 HO, ZJ 242, 4.5 Rustys, 33" Mud terrains
My build:
overlandchris is offline
where can i find a 3/4-1 inch wj coil spacer??? wonderbrd937 WJ Grand Cherokee Forum 13 04-17-2011 08:15 PM
Death wobble after installing 2" coil spacer lift !!help!! tahoe_on44s WJ Grand Cherokee Forum 2 04-11-2011 11:53 AM
Can you stack a spacer on top of a coil spring lift kit? NewtonGT WJ Grand Cherokee Forum 20 02-20-2011 09:19 PM
Looking for a .75-1" front spring spacer... Nubster WJ Grand Cherokee Forum 21 10-28-2010 09:57 AM
Daystar coil spacer installation on 2001 WJ lapinski89 WJ Grand Cherokee Forum 2 02-03-2009 02:27 PM
