BCM Issues? - JeepForum.com
post #1 of 2 Old 10-18-2013, 05:07 AM Thread Starter
JeepsOLot
BCM Issues?
We had the strangest things happen at once last night. This is an '04 GC Laredo with the 4.0.
The interior lights would stay on, even while driving. The driver's side door will not lock and unlock with the fob, and when I try to unlock and lock all doors at the drivers side door, only that drivers side door works. And, even when the horn chirping and lights flash when the doors are locked from the fob is selected, none works when using the fob.
Now, I did pull the battery cable for 5 mins, and got the interior lights to work as they should, but, still have the other problems. Anyone had issues like this, is it the BCM or something else? Thanks!
Jerry
86 MJ LB Custom, 88 MJ SB Eliminator, 92 CJ9, 93 XJ Country, and 04 WJ Laredo/Limited
JeepsOLot is offline
post #2 of 2 Old 10-18-2013, 08:43 PM Thread Starter
JeepsOLot
Well, I found a broken wire between the passenger side front door and the body. Fixing that fixed the door locking issues. I disconnected the battery for 20 mins, and that seemed to fix the other issues. We'll see if that truly fixed everything, I hope so!
Jerry
