BB Only Just installed, now loud 'hum' - JeepForum.com
post #1 of 13 Old 10-21-2010, 12:06 PM Thread Starter
outlaw30
I have a 2001 Limited, Quadratrac II, was all stock (not Overland). Just had a 2" BB installed, now I have a really loud hum and vibration from the front end, that starts at about 15mph. It gets slightly quieter at above 40mph. Also, when I hit the brakes at around 40 when its really noisy, the front end dives and the sound goes away until the suspension picks back up and the noise returns.
Front driveshaft angle? CV joint gone? It had a slight hum at highway speeds before the BB, but got MUCH louder after the BB.
Any suggested fixes is much appreciated.
outlaw30 is offline
post #2 of 13 Old 10-21-2010, 12:12 PM
narnwv
narnwv's Avatar
front drive shaft it sounds like. Mine was making a bit of noise before my BB (rear CV's boot was ripped), and after the BB, all the bearings shot out of it.
~Aaron
narnwv is offline
post #3 of 13 Old 10-21-2010, 12:13 PM
g4x4xgeoff
sounds like your front driveshaft is binding a bit.
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #4 of 13 Old 10-21-2010, 12:18 PM Thread Starter
outlaw30
any thoughts on whether it will 'wear in' or am I asking for trouble?
outlaw30 is offline
post #5 of 13 Old 10-21-2010, 12:21 PM
g4x4xgeoff
you're asking for trouble. binding is essentially putting your ujoints at an angle they're not designed to be at.
Your driveshaft could be just bent a little and need balancing, but i don't think that it's your issue since you said it stops when you're braking. Take a look each end of your driveshafts and see if the angles look severe, if in doubt snap a photo
post #6 of 13 Old 10-21-2010, 12:34 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Sounds like the typical Repezza type driveshaft going bad. Nothing new. Just got worse with the BB installed. Time to replace it or upgrade to a double cardan.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #7 of 13 Old 10-21-2010, 12:47 PM Thread Starter
outlaw30
will the Double Cardan solve the issue or should I look at somehow changing my front driveshaft angle? No long miles are going on this thing, only 50 miles each way to wheel in the desert. thoughts?
outlaw30 is offline
post #8 of 13 Old 10-21-2010, 12:53 PM
WiCkeDuDe
WiCkeDuDe's Avatar
There are many many threads on here about how they go bad even in stock height. It was a bad design thus in 02 the double cardan came out. At 2" the repezza is okay but going to the double cardan would be better.
post #9 of 13 Old 10-21-2010, 02:12 PM Thread Starter
outlaw30
I searched everything on here, just had never heard of a BB causing such a problem with driveshaft angle; I thought that only happened at 4" or more of lift. I guess its park the thing till I get a Double Cardan....thats like 3 weeks of parking it, I'm in the UAE and sourcing parts is a REAL pain.
outlaw30 is offline
post #10 of 13 Old 10-21-2010, 02:25 PM
WiCkeDuDe
WiCkeDuDe's Avatar
The angle doesnt. Read what I wrote. They go BAD even at STOCK height. The driveshafts were the problem, thus they changed to a double cardan. Tons of people run BBs with no problems.
post #11 of 13 Old 10-21-2010, 02:43 PM Thread Starter
outlaw30
I read what you said...and you're right, they do go bad...read all about it. Just didn't thing a simple BB lift would change it so drastically. Appreciate the advice.
outlaw30 is offline
post #12 of 13 Old 10-21-2010, 04:23 PM
99WJNM
changing to a double cardan will fix you up... i got lucky on my 99 and the P/O had already had the shaft changed.
99WJNM is offline
post #13 of 13 Old 10-23-2010, 04:56 AM Thread Starter
outlaw30
fixed
Driveshaft was the problem. I had the stock Rapezza - Rapezza (sp?) on there, probably since new (125k now). Couldn't wait on getting a Double Cardan from the US (I'm in Abu Dhabi), so I had another stock type put in -- sound gone, fixed. Thanks for the advice guys.
outlaw30 is offline
WJ: Loud hum at highway speeds W3MOT WJ Grand Cherokee Forum 10 12-19-2010 12:40 PM
New muffler (from Firestone) is way too loud. What next? dbonneville WJ Grand Cherokee Forum 6 10-01-2010 05:16 PM
Loud whine from WJ (unlike others in forum) uberkup WJ Grand Cherokee Forum 3 04-08-2010 11:04 AM
Why Is My Fan So Loud!? joshjones84 WJ Grand Cherokee Forum 6 03-13-2010 07:04 AM
loud exhaust and good sound mikkjroverland WJ Grand Cherokee Forum 0 08-10-2003 08:22 PM
