BB and 255/70s? - JeepForum.com
post #1 of 7 Old 03-14-2010, 12:11 AM Thread Starter
kirbWJ
1994 XJ Cherokee
BB and 255/70s?
ive been contemplating on 245/75s or 255/70s.my question is - will 255s rub? and if so can somebody explain to me HOW i trim whatever it is i have to trim.i want to run the biggest tire i can with my BB... even a 265 has come to mind. in advance, i know im ignorant... but we all have to learn somewhere!
P.S. i have searched the forum for something on 255 tires and a BB, but couldnt find anything. sorry if this is a thread somebody has posted a thousand times.
kirbWJ is offline
post #2 of 7 Old 03-14-2010, 12:14 AM
WhiteOut
WhiteOut's Avatar
Assuming that you plan on running a 16" rim, both will fit with no issues. A 245/75/16 is a 30.5" tire, a 255/70/16 is a 30.1" tire.
WhiteOut is offline
post #3 of 7 Old 03-14-2010, 12:35 AM Thread Starter
kirbWJ
1994 XJ Cherokee
thanks for the reply, im thinking the 255s simply because they are a little bit wider (i recently rolled my jeep at 50 and drove away home with only a few dents and a slight single tire balance issue) needless to say, im scared of rolling my jeep again...BUT I WANT CLEARANCE!!!!! so im trying to get a wider track for better stability, but at the same time dont want to use spacers because of the wear and tear, or go through the trouble and expenses of buy a backspaced rim (which i know little about).
will the 255s compared to the 245s give me better stability? and if i did want to go for 265s would i have to go with a wider than stock rim?
kirbWJ is offline
post #4 of 7 Old 03-14-2010, 12:37 AM
PhantomWJ
2003 WJ
265's will rub with a 2" BB..255 will have minor rubbing on the inside plastic of the bumper/fender at full lock...from my experience
PhantomWJ is offline
post #5 of 7 Old 03-14-2010, 07:11 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
I only had minor rubbing issues with the 255's with out the BB, after I put the BB on, no rubbing issues at all.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #6 of 7 Old 03-15-2010, 10:51 AM
WJJIM02
Through my experiance:BB with 255/70/17 REVO's on an '02 WJ will just barely touch the drivers side inner fender at full lock in reverse.
WJJIM02 is offline
post #7 of 7 Old 03-15-2010, 11:00 AM
ruggedscotsman
2007 WK
You rolled your Jeep with only a few dents.... PICS?
ruggedscotsman is offline
