Battery? or something more on a WJ - JeepForum.com
post #1 of 16 Old 02-28-2013, 12:46 PM Thread Starter
Cxrob
Son went to start his 02 WJ today and each time he gets a slow crank with dim lights and it then starts. Sound to me to be the battery (Last week we changed the fan relay switch - which was leaving the fan running and draining the battery)... it was starting fine for the last 5 days until now.
Can someone tell me what voltages I should be reading at the battery off and running?
Cxrob is offline
post #2 of 16 Old 02-28-2013, 12:51 PM
Red350ss
Battery off should be between 12.0 and 12.8 volts, running should be in the mid 13 to 14ish volt range.
Barron
2004 WJ Overland
Red350ss is offline
post #3 of 16 Old 02-28-2013, 03:08 PM Thread Starter
Cxrob
Can someone tell me what size battery an 02" WJ with 4.0 should take?
Cxrob is offline
post #4 of 16 Old 02-28-2013, 03:33 PM Thread Starter
Cxrob
Cxrob is offline
post #5 of 16 Old 02-28-2013, 04:13 PM
cuttysark
around 700 CCA - im basing this on my 4.7 taking 850
cuttysark is offline
post #6 of 16 Old 02-28-2013, 04:35 PM
bradywgn71
bradywgn71's Avatar
Group 65
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline
post #7 of 16 Old 02-28-2013, 04:52 PM
gcjeeping
gcjeeping's Avatar
Biggest one(s) you can fit...lol
_____________
gcjeeping is offline
post #8 of 16 Old 02-28-2013, 05:06 PM Thread Starter
Cxrob
SO.. my son jsut got home and here's the sympton
turn key on dash and headlights are fine... go to start and the lights dim and after a slow crank she starts.
Sounds like a weak battery to me - no?
the battery died a few times last week (fan relay switch keep fan running so we repalced it)
from the feedback looks like its a group 65 - I see Sears has a 650 and 850 CCA... guess there's no harm going wiht the 850.
Cxrob is offline
post #9 of 16 Old 02-28-2013, 05:16 PM
gcjeeping
gcjeeping's Avatar
Make sure your battery connections are clean.
Have the battery tested. I have always checked bad batt cables by bypassing them with a good set of jumper cables one at a time. Sometimes a batt cable will corrode from the inside especially the ground. A bad cable will allow enough amps for lights but not crank.
Then it would be alternator to have checked.
Also if you have a known good battery to put in (doesnt matter what size) and try to see if it starts right up. I took my battery out of my Escort and put in my jeep to test one time to see if it was the batt.
_____________
post #10 of 16 Old 02-28-2013, 07:03 PM
Schlotzky
2007 XK Commander
x2 on getting it tested. Autozone will do this for free in the car in the parking lot.
Sounds like a bad battery to me. Full cycles (battery dying and then being fully recharged) is terrible for car batteries and can kill them pretty quick.
Schlotzky is offline
post #11 of 16 Old 02-28-2013, 07:07 PM
murph0124
2003 WJ
could be bad starter drawing down when it cranks also
murph0124 is offline
post #12 of 16 Old 02-28-2013, 07:47 PM
JRT403
^ can definitely be a starter as well. I had a starter go out, tested out fine at Autozone, but the old man there told me it didnt sound like it was quite winding up as it should--took a new one off the shelf and tested it and you could clearly hear the difference between the two. Something to consider.
http://www.jeepforum.com/forum/f197/jrt403s-wj-build-thread-1242747/
JRT403 is offline
post #13 of 16 Old 03-01-2013, 09:04 AM
Indslpwr04
Check all your heavy gauge engine ground connections. I had an old bronco that wasted the battery, alt, and starter in a 3 month period because the battery to engine, engine to frame ground cables were severely corroded. Its free too.
2002 Overland. All stock, for now.
Indslpwr04 is offline
post #14 of 16 Old 03-01-2013, 02:44 PM
Cebby
How old is the battery?
2000 WJ Laredo 4.0 4x4 Taupe Frost - Stroker | Clayton LA w/3" Lift | 33's on JK 17's | Axles next
Cebby is offline
post #15 of 16 Old 03-03-2013, 05:31 PM
murph0124
2003 WJ
i did a 4.0l engine in a 99 wj and the engine block was painted and the grounds that go by the cam sensor area werent making good contact do to the paint. Maybe the grounds there are making poor contact with the block?
