Battery/Alternator? - JeepForum.com
post #1 of 11 Old 06-23-2013, 04:19 PM Thread Starter
RepomanNC
Battery/Alternator?
Got into my 2001 WJ 4.7 to take my boys to a movie. Heard a constant dinging and saw a light lit up that read "Check Gauges". The only gauge I saw that looked off was my Battery Gauge, it looked low. Saw the movie got in the jeep, it started but on the way home the needle just kept dropping. Got home pulled it in the garage, shut it down and tried to restart 3 minutes later...dead. Sounds like the alternater to me. any other thoughts? Charging the battery now, hopefully enough to get me the 16 miles to work at 5 tomorrow morning. I can work on the altenator there if needed. Do I need a Mopar one or will a napa/autozone one be good enough?
RepomanNC is offline
post #2 of 11 Old 06-23-2013, 04:27 PM
cykaaro
Sound like possibly the alt. As long as the battery wasn't drained right down it should be ok. I've never had any issues with anything I've bought at napa, and prices have always been pretty good for around here anyways.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #3 of 11 Old 06-23-2013, 04:29 PM
pinky2252s
Most likely the alternator. I would pull it and go get it tested along with the battery. If the alternator needs to be replaced, any brand will work. I got a rebuilt one for like 90 bucks after the core return. I had to replace mine because of a bad bearing.
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #4 of 11 Old 06-23-2013, 05:38 PM Thread Starter
RepomanNC
thanks for the replys. Fingers crossed I make it to work!
post #5 of 11 Old 06-23-2013, 07:08 PM
buger561
2003 WJ
If you have an Advanced Auto nearby there's a coupon code for 30% off of a purchase of $50+.
You can order online and pick up in store.
The code: TRT30
Also $40 of of $110+ (or $25 off $70)
Code: RETMENOT124
buger561 is offline
post #6 of 11 Old 06-23-2013, 10:03 PM
3Dog
3Dog's Avatar
Alternator...
3Dog
2015 WK2 Overland Hemi ORA II
2000 WJ Limited 4.7L (sold)
3Dog is offline
post #7 of 11 Old 06-24-2013, 06:16 AM
cubalz
Definitely the alternator. Happened to me in the exact same way.
2003 Rubicon - 33x12.50x15 GY Duratracs, 15x10 MT Classic Locks, 2" BL, 2" BB, Warn Front Bumper, Garvin ATS Rear Bumper, Body Armor Extreme Rock Rails, Nth Degree Tummy Tucker, Skid Row Engine, LCA and Gas Tank Skid Plates, Teraflex Quick Disco's, Uniden Pro 520xl CB, 3' Firestik Antenna, BW Flat Fender Flares, Tom Woods DS, Currie Rear Adj Arms
cubalz is offline
post #8 of 11 Old 06-24-2013, 11:56 AM Thread Starter
RepomanNC
That is what it was. Was able to charge the battery enough to get me to the office. Disconnected the negative side of battery, Jeep died. Replaced the Alt in a few minutes, good as new!
post #9 of 11 Old 06-24-2013, 01:50 PM
cykaaro
Good to hear!
cykaaro is offline
post #10 of 11 Old 06-24-2013, 07:01 PM
Double E
Double E's Avatar
I wish I had seen this earlier....you would have been better off to get the Durango alternator for it. Costs less and puts out 160amps as opposed to the 132amps. Direct fit. Search my posts for details.
The Autozone unit is fine though... damn...could have helped a brother out. Oh well, good diagnosis from the folks here & glad you got it sorted.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #11 of 11 Old 06-25-2013, 05:17 AM Thread Starter
RepomanNC
Next time it goes out...and I'm sure there will be a next time. I'll take you suggestion and go with the Durango Alt. Appreciate the information.
