Bars radiator leak stop? - JeepForum.com
post #1 of 14 Old 11-04-2013, 10:00 AM Thread Starter
tjmortenson
So after driving g on some rough trails a couple days ago, I noticed yesterday my radiator had a small leak, just enough to wet the fender after it sat for a day. Today I drove the half hour to school and as soon as I pulled in to the parking lot it started beepi g and saying g low coolant. I got out and here is a steady drip coming from the bottom of the radiator. Should I use bars leak stop to seal it to get home or just try to buy a gallon of antifreeze to make it home? I know I need to replace the radiator, its just not in my budget now.
Thanks
tjmortenson is offline
post #2 of 14 Old 11-04-2013, 10:17 AM
alfaitalia
DO NOT PUT BARS IN YOUR ENGINE...ok enough shouting! Just keep an eye on the level and keep topping. Using any of those radiator sludges will store up problems for the future in the form of blocked water channels or heater cores unless you are very lucky.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is online now
post #3 of 14 Old 11-04-2013, 11:05 AM
88yjproject
NO BARS LEAK! Does more harm than good.
2002 WJ 4.0 3" IRO, ES9000 shocks. Midland CB. 245/75R16 Dunlop M/T.
HydroLocked Offroad
88yjproject is offline
post #4 of 14 Old 11-04-2013, 11:31 AM
MadderThanMax
YEAH, I'LL SHOUT A BIT MORE TOO!! NO BARS RAD LEAK!! Unless to want to gunge up the system even more..
MadderThanMax is offline
post #5 of 14 Old 11-04-2013, 12:40 PM Thread Starter
tjmortenson
Alright I bought a gallon and I'm going to order a new radiator, this one should work correct? Mines a 1999 4.7 v8. http://m.ebay.com/itm/300583143733?nav=WATCHING&sbk=1
post #6 of 14 Old 11-04-2013, 01:16 PM
88yjproject
Why not go to auto zone and get a lifetime warranty one?
HydroLocked Offroad
post #7 of 14 Old 11-04-2013, 02:52 PM Thread Starter
tjmortenson
I guess that would be what I should do, but I really can't afford to spend $150. I would like to get one for 75 on eBay but who knows how long it will last.
post #8 of 14 Old 11-04-2013, 03:28 PM
dlundblad
2003 WJ
Yeah don't run that **** in your engine. Just go to the local Wal-Mart and buy some cheap Supertech antifreeze 50/50 stuff. Its going to leak out so the cheaper the better.. lol
03 WJ Laredo 4.Sl0w
2" BB, Overland Skids
2nd set of 245/75/16 DuraTracs
dlundblad is offline
post #9 of 14 Old 11-04-2013, 03:45 PM
yzjwk
2005 WK
2 tablespoons of black pepper has always worked for me in the past . I've used it a few times and it has never gunked up the system like Bars leak will . Just have to rinse the system when your done .Your going to want to flush and fill with a new rad anyways .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #10 of 14 Old 11-04-2013, 03:46 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Some ******* told my wife to put bars stop leak in our WJ. When the radiator started to leak. It stopped the leak, 2 days later the WJ overheated cause of clogged coolant passages then it blew a head gasket and filled #8 with coolant. A few hours later she tried to start it and bent a rod.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #11 of 14 Old 11-04-2013, 08:20 PM Thread Starter
tjmortenson
Well I bought the cheap Walmart coolant to fill it for now, and I ordered the eBay radiator. I'll keep everyone posted on how it works out.
Thanks for all the help guys.
post #12 of 14 Old 11-04-2013, 10:36 PM
indept
Now that everyone said "DONT USE BARS LEAK"
Go ahead use it, NO NOT THAT BLACK LIQUID crap,
use this:
I've used this in my last 3 cars. A GM trained mechanic told me that years ago they put this in new cars (He's a friend of mine so I believe him). NEVER clogged my engine or heater core. Stopped a leak in my old Toyota 4wd wagon. Lasted 7 years until I got rid of it, no leaks never clogged it. I put it in my Jeep every time I've changed the anti freeze, NO problems at all. I usually get it at Napa.
Just crush them with pliers and put it right in the radiator or in the top hose & was it down with some antifreeze.
2000 WJ 4.0L 42RE 242 TC
190,091 miles & counting
indept is offline
post #13 of 14 Old 11-05-2013, 05:16 AM
86cj74.2L
86cj74.2L's Avatar
Originally Posted by indept
Now that everyone said "DONT USE BARS LEAK" Go ahead use it, NO NOT THAT BLACK LIQUID crap, use this: I've used this in my last 3 cars. A GM trained mechanic told me that years ago they put this in new cars (He's a friend of mine so I believe him). NEVER clogged my engine or heater core. Stopped a leak in my old Toyota 4wd wagon. Lasted 7 years until I got rid of it, no leaks never clogged it. I put it in my Jeep every time I've changed the anti freeze, NO problems at all. I usually get it at Napa. Just crush them with pliers and put it right in the radiator or in the top hose & was it down with some antifreeze.
Saturn did that as well. So when I put a new head on it I put some copper stuff in also.
86cj74.2L is offline
post #14 of 14 Old 11-05-2013, 06:22 AM
88yjproject
Still would never use it. No need for it.
HydroLocked Offroad
