Bad piston rings? - JeepForum.com
post #1 of 6 Old 08-07-2010, 12:53 AM Thread Starter
97DCZJ
Bad piston rings?
99 WJ 4.7L, 149xxx miles.
I burned almost about 5 quarts in 3,000 miles, obviously keeping it up to level throughout time, just all added up to that. I don't overheat, and I just changed the oil and it wasn't milky, and replaced the radiator and coolant seemed pretty good so that throws bad head gasket out of the question. It puffs blueish smoke sometimes at start, but puffs from stopsigns/stop lights almost everytime. Just replaced the PCV valve, and old one seemed to be fine anyway.
I almost have this down to almost bad rings or valve guides. How much of a PITA would it be to pull the motor and fix these?
1997 Grand Cherokee Orvis: V8 5.2L, stock.
(Sold) 1998 Cherokee Sport: 4.0L I6, Stock.
(Sold) 1990 Cherokee: 4.0L I6, 4.5" Lift, 33" BFG's.
(Sold) 1997 Grand Cherokee Limited: V8 5.2L, 2" BB, 31" Dick Cepeks.
(Sold) 1999 Grand Cherokee Laredo:
; V8 4.7L, Stock.
(Sold) 1996 Grand Cherokee Laredo:
; V8 5.2L ,3.5" lift, 32" Tires
97DCZJ is offline
post #2 of 6 Old 08-07-2010, 12:59 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
A big pita actually.
ratmonkey is offline
post #3 of 6 Old 08-07-2010, 08:49 AM
comptiger5000
Do a compression test, see what it comes back as. Then, add about a teaspoon of oil to each cylinder and retest. If the compression goes up, it's bad rings. If it doesn't, it's valve guides. If that test shows it's rings, they may just be stuck, not bad.
To try to free up stuck rings, buy a quart of Marvel Mystery Oil (MMO). It's about $5. Pour an ounce or 2 into each cylinder through the spark plug hole (leave the plugs out). Let it sit overnight. In the morning, place some rags in front of the spark plug holes, and crank it for a few seconds to push any remaining oil (that didn't seep down past the rings) out. Use the rest of the quart as your top-off oil until you finish the quart. Run the oil/MMO mix for about 1000 miles, then change the oil and filter. If the rings were gummed up and sticking, this should clean them up a good bit and reduce your oil consumption.
comptiger5000 is offline
post #4 of 6 Old 08-07-2010, 09:03 AM
Howiedooit
on a daily driver stuck rings are unlikely, worn rings are also unlikely with only 147k, if the problem began out of the blue then I'd lean more towards a cracked ring. If you do have a cracked ring then fixing it becomes a little more complicated depending on weather it dislodged from it's groove and had a fight with your cylinder wall on it's way out. X2 on the comp test tho
Howiedooit is offline
post #5 of 6 Old 08-11-2010, 04:09 PM
99_WJ_Laredo
Originally Posted by comptiger5000 View Post
Do a compression test, see what it comes back as. Then, add about a teaspoon of oil to each cylinder and retest. If the compression goes up, it's bad rings. If it doesn't, it's valve guides. If that test shows it's rings, they may just be stuck, not bad...
What are the compression numbers supposed to be for an engine in good condition?
99_WJ_Laredo is offline
post #6 of 6 Old 08-11-2010, 04:33 PM
Bama_WJ
Bama_WJ's Avatar
Good info here...
compression check - Dakota Durango Message Board
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
piston carbon squazz ZJ Grand Cherokee Forum 11 12-02-2010 12:50 AM
Piston Rings tacweapon ZJ Grand Cherokee Forum 2 03-18-2010 12:56 PM
Piston Ring Help jeepdudeuk ZJ Grand Cherokee Forum 1 10-01-2009 10:37 PM
4.7 HO piston slap JForest2 ZJ Grand Cherokee Forum 5 08-17-2009 12:29 PM
new caliper piston captain_andrew ZJ Grand Cherokee Forum 1 05-31-2004 02:54 AM
