Bad calipers/ master cylinder / brake lines?? - JeepForum.com
post #1 of 3 Old 03-19-2012, 09:50 PM Thread Starter
brycherokee87
2015 JK Wrangler
Wj Bad calipers/ master cylinder / brake lines??
Sorry everyone, I have been putting post after post. I have a bad grinding/rubbing and noise when braking. I have a brake light on, which switches every other week from the abs light to the brake light. After parking I smell a burning front the front tires, but the car does not pull to on side or another when I brake. Hooked it up to the computer and it's reading bad abs sensors, and bad brake fluid sensor..the reservoir is full. I can careless if I have no abs, I just want the truck to stop smoothly. Could these braking issues be caused from a bad caliper, master cylinder, or a bad brake line? I took it to jeep and they have no idea, I changed the pads and rotors also. So that's not the issue.
The jeep mechanics told me I have bad carrier bearings and pinion bearings in the front, not sure if that would be causing my braking issue or has anything to do with it. Thank you everyone
02 WJ, 4.0 155k
brycherokee87 is offline
post #2 of 3 Old 03-20-2012, 10:11 AM
RebelX
Smells like burning what? Hot brakes? You may have a stuck caliper slide. That can cause a pad to stay in constant contact with the rotor and eventually smoke the pads. A bad brake hose can cause similar issues, and it may not always look bad. They can break down on the inside and cause the caliper to hang.
RebelX is offline
post #3 of 3 Old 03-20-2012, 01:58 PM Thread Starter
brycherokee87
2015 JK Wrangler
oh sorry, it smells like burning rubber from the front wheel. when the guy did my hubs he put the truck on a lift and let the calipers hang freely, which i didnt like. when i left the shop my brake light when on, and when driving and applying the brakes I heard a snap from the front end if i braked hard. Now I have a grinding and rubbing noise, and the front right wheel smells like burning rubber.
brake calipers vczar1 WJ Grand Cherokee Forum 4 03-06-2012 08:27 AM
WJ brake calipers rbgfishboy WJ Grand Cherokee Forum 3 10-26-2011 08:03 AM
Brake Calipers jeeper23 WJ Grand Cherokee Forum 4 09-13-2011 01:29 AM
Master Cylinder Reservoir Question Twospeed WJ Grand Cherokee Forum 1 10-10-2010 10:17 AM
Master Cylinder Upgrade Options sa863c WJ Grand Cherokee Forum 1 07-13-2010 11:27 AM
