Axle swap guide - 1/2 ton - Page 6 - JeepForum.com
post #76 of 97 Old 06-30-2014, 08:28 PM
dlundblad
2003 WJ
Dang Tom! I had no idea you were putting this beast together. It is looking exceptionally well. Great job on all the welds and detailed pics.
03 WJ Laredo 4.Sl0w
2" BB, Overland Skids
2nd set of 245/75/16 DuraTracs
dlundblad is offline
post #77 of 97 Old 07-15-2014, 06:27 PM Thread Starter
skain8
skain8's Avatar
Originally Posted by fast540 View Post
Mr skain, nice to see your rig together. Bet you won't be breaking axles anytime soon
Thank you, sir. Doubt it!
Thank you as well, sir.
Originally Posted by thejeep88 View Post
You gonna have this beast at the all breeds jeep show in a few weeks?
Doesn't look like the jeep will be there, but I plan to. Look for EndlessMtnFab!
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #78 of 97 Old 07-15-2014, 06:33 PM Thread Starter
skain8
skain8's Avatar
9" drain
Added a drain to the 9". Props to StrokedWJ for the suggestion and the pic earlier in the thread. Here's what we came up with for max function and low-profile protection -- you can see it is recessed, reinforced (just a tad ), and a magnet was jb welded to the to inside plug to catch any metal. Notice the rear truss burn marks on pic #4?
Name:  9paint.3rd member,drain.jpg
skain8 is offline
post #79 of 97 Old 07-16-2014, 11:13 AM
StrokedWJ
StrokedWJ's Avatar
^ Nice work! That came out really nice!
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #80 of 97 Old 07-21-2014, 06:05 PM Thread Starter
skain8
skain8's Avatar
Front & rear swaybar
Front swaybar is retained. Creativity was needed for the front swaybar links in order to achieve optimal angle (i.e. parallel with the lower control arm) while avoiding any interference of the front steering or suspension. Here is the driver's side design. Passenger is similar, and was much easier since no steering links to contend with. WJ style JKS disco's are used (open loops top/bottom). The pics are a bit deceiving -- there is plenty of clearance between the link arm mount and the trackbar.
Rear swaybar is mounted to the truss. If the gas tank was raised, it could be mounted much higher up, but as it currently sits, there is no clearance issues with the stock tank skid. Rear swaybar links are JKS disco's (not pictured) -- not for disconnect function, but moreso for flex. I like the stock rear swaybar connected.
In this pic, you can also see the rear shock mount. The goal was to position the shock for optimal dampening (i.e. as close to perpendicular to the ground as we could get, within reason given design limitations).
Name:  rear shock swaybar combo.jpg
skain8 is offline
post #81 of 97 Old 07-21-2014, 06:13 PM Thread Starter
skain8
skain8's Avatar
Thanks.
Provided some more content re: ABS, speedometer and brakes (prop valve) early in thread at post #5.
skain8 is offline
post #82 of 97 Old 08-26-2014, 06:53 PM Thread Starter
skain8
skain8's Avatar
POR, primer & paint on the 9"
Light dusting etch primer after bare metal was POR'd:
Name:  9 primer front view.jpg
Name:  9 primer rear view.jpg
1st coat topcoat:
Name:  9 black topcoat rear view.jpg
skain8 is offline
post #83 of 97 Old 09-02-2014, 07:13 AM Thread Starter
skain8
skain8's Avatar
PM's replied to. If you have a specific question, please just post it and I'll do my best to answer.
Also, I added some additional info regarding the speedometer in post #5. BTW, anyone have a 39 tooth speedo gear laying around?
Cheers.
skain8 is offline
post #84 of 97 Old 09-02-2014, 10:00 AM
mtnmarc
Glad to see you figured out the speedo wiring man!
It was a pain when I did it cuz not a lot of true info was out on the interweb. A few people had ideas, but nothing really to follow. And that was a good thing to say that Chrysler has different colors for wires, because I ran into that issue first hand. Haha. Where are the full widths and coilovers
And with the speedo gear, mine with 5.38s and 37s is dead on with a 41 tooth I believe.
99 WJ hp44, 3 link, Eaton e locker, 14" foa coilovers in the front. 14 bolt, 4 link, grizzly locker, 12" foa coilovers in the rear. 5.38s and 37s
mtnmarc is offline
post #85 of 97 Old 09-23-2014, 05:35 PM Thread Starter
skain8
skain8's Avatar
231 speedo
As Mtnmarc wrote above, the speedo wiring was a bit of a struggle. I revised the thread a bit for that section (post #5), hopefully for others to avoid our headaches. Here is the 231 with the speedo port, which was previously sealed off:
And here is the finished product with the speedo gear in place and wiring run back along the rail to the driver rear speed signal wiring:
Name:  231 wiring.jpg
skain8 is offline
post #86 of 97 Old 09-23-2014, 05:41 PM Thread Starter
skain8
skain8's Avatar
D44 updates
Here is the D44 w/primer and ready for paint:
Name:  d44 primer.JPG
D44 back under the truck. Picture of the driver spindle, hub, lockout assembly. Note: when using manual lockouts such as Warn, the drive slug springs are not used (shown in picture for illustrative purposes only).
Name:  driver spindle.JPG
Name:  driver spindle 2.JPG
Name:  warn lockout complete.JPG
skain8 is offline
post #87 of 97 Old 09-23-2014, 05:44 PM Thread Starter
skain8
skain8's Avatar
9" assembly
9" under the truck. Pic of the rear drums. Salvage what you can from the donor axle, but drum rebuild kits are cheap, so spend a bit for peace of mind and ease of install.
Name:  rear drum complete (1).JPG
More pics to follow...
skain8 is offline
post #88 of 97 Old 09-23-2014, 07:05 PM
gtg413i
2003 WJ
Very nice. Can't wait to see this baby showing up some wranglers.
Brian's Black Betty Build:
gtg413i is offline
post #89 of 97 Old 09-23-2014, 07:22 PM
wvracer821
wvracer821's Avatar
really nice job on the swap, i cant wait to see this thing on the trail. ive been taking notes for when swap the 60 and 10.25 into my turd
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
post #90 of 97 Old 09-24-2014, 05:56 AM Thread Starter
skain8
skain8's Avatar
Thanks, fellas. If you have any specific questions, just ask. If I don't know, I know someone that will.
skain8 is offline
