Axle swap guide - 1/2 ton - Page 4 - JeepForum.com
post #46 of 97 Old 12-16-2013, 09:03 PM
Kodiak17
Cool stuff. Come to RC this sunday, I'd love to see it in person.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #47 of 97 Old 12-28-2013, 06:52 AM Thread Starter
skain8
skain8's Avatar
No dice. See you in the spring.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #48 of 97 Old 12-28-2013, 06:58 AM Thread Starter
skain8
skain8's Avatar
Updated 9" pics
Here are a few more pictures of the 9" *mostly* complete (no shock mounts or swaybar mounts in these pics, or gears, paint, etc... ).
Front:
Rear:
Angle:
Full compression w/drum. Note: the tank will be chopped, but the axle truss fits under full compression with no modification:
skain8 is offline
post #49 of 97 Old 12-28-2013, 09:00 AM
fast540
Looking pretty awesome
fast540 is offline
post #50 of 97 Old 12-29-2013, 06:52 AM Thread Starter
skain8
skain8's Avatar
Thank you.
The nice thing is, that apart from the complete axle kits, several of these individual components incorporated into the overall build (i.e. rear swaybar frame plates, coil retainers, etc..) are specific to the WJ, not available elsewhere, and can be used with any lift, or even stock.
skain8 is offline
post #51 of 97 Old 01-03-2014, 07:56 PM
Eshindi
Love the swap, I did the exact same swap for my WJ. Except that I went with rear disc brakes and no truss yet.
Great write up too. Did you have a speed sensor in your Transfer case or does your WJ use the ABS sensor for the speedo?
'15 JK Stock | 4k Miles | Bone Stock
SOLD '99 WJ I6 | Claytons LA | 6.5" | HP D44 | F9" | 35's
Eshindi is offline
post #52 of 97 Old 01-04-2014, 05:20 PM Thread Starter
skain8
skain8's Avatar
Thanks.
Speed sensor in 231. ABS delete.
I know where you can get a truss for your 9".
skain8 is offline
post #53 of 97 Old 01-05-2014, 10:29 AM
StrokedWJ
StrokedWJ's Avatar
Maybe I missed it, but any thoughts/provision for a rear sway bar? You may want to think about adding a drain plug to the bottom of the 9 too.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #54 of 97 Old 01-05-2014, 01:00 PM Thread Starter
skain8
skain8's Avatar
Rear swaybar pics/info not yet added. Stock bar retained. Using TJ style JKS disconnects, modified for length. Swaybar brackets welded to rear of truss. Mounts raised high as possible without inference with the OEM tank skid while retaining optimal angle.
As far as the drain plug, it was considered, but the shape of the 9" requires the drain to be on the very bottom. Enough gouging and scraping and it becomes difficult to remove. A hardened washer can be welded in and serve as a skid, but it would obviously stick out a bit and potentially catch or snag. Only one opinion, of course.
skain8 is offline
post #55 of 97 Old 01-05-2014, 02:02 PM
StrokedWJ
StrokedWJ's Avatar
. That's where I put mine. Pretty well hidden and drains all but the very last bit of fluid. Enough to decrease the waterfall mess. Lol
post #56 of 97 Old 01-06-2014, 05:38 PM
Eshindi
One other thing I'm jealous of is the fact that it looks like you kept your rear lower spring isolator in the rear. The claytons kit doesn't keep the isolator so the spring is right against the metal and it really gets noisy when on a bumpy road. I really want to copy our design to make my rear more quiet.
Eshindi is offline
post #57 of 97 Old 01-06-2014, 07:38 PM Thread Starter
skain8
skain8's Avatar
Post #44 shows the front and rear coil designs, which do retain the factory isolators upper & lower. The f/r bottom isolators fit snugly onto a cup to hold them firmly into place.The half-moon retainer is then bolted to the cup. Pretty slick. No one likes clangy springs.
skain8 is offline
post #58 of 97 Old 01-26-2014, 03:57 PM Thread Starter
skain8
skain8's Avatar
For the rear swaybar links, I am using JKS disconnects from a TJ. I intend to keep the rear swaybar hooked up, but the TJ JKS disco's will permit more free movement of the swaybar with articulation. The TJ disco's are too short at my lift height, so they had to be modified. Originally, the thought was that the thread rod was glued into the eye piece. Heat didn't work, so it was cut off, ground smooth, and will be drilled and tapped with longer threaded rod.
Heat didn't work:
Cut and ground flat:
The "frame" rail at the upper rear swaybar was cracked. This was with the stock rear swaybar. It was permanently fixed with a plate. This fix/strength upgrade is a wise choice for the masses (especially those with the Addco), and should be available from Endless Mtn Fab soon.
Crack (cleaned):
Weld crack:
Grind clean:
Zinc pain between new plate and frame rail:
Plug & perimiter weld the plate:
skain8 is offline
post #59 of 97 Old 01-26-2014, 04:34 PM Thread Starter
skain8
skain8's Avatar
Steering - update to post #8
Post #8 of this thread shows the mock-up of the inverted Y steering. Here is how it looks now [mostly] complete
This is the draglink, which in an inverted Y design, attaches to the knuckle and the tie rod attaches to it. This piece is completely fabricated, with the machined metal insert piece interference fit in the tube, then plug and perimeter welded, and ground smooth:
Front view. Yes, the trackbar is there, you just can't see it because the geometry is that good . This is at ride height. Notice the flat angles of the draglink and trackbar (+/- 10*), and the lengths of these bars. Overall length of the trackbar and draglink are within a 3/8" of each other. The steering is so long I have come to refer to it as the Lexington Steel inverted y:
Side view towards the pitman arm. Note the clearance and how parallel and in plane the trackbar and draglink are.
Here is a better pic of the front, showing the fabricated draglink and the steering in general (yes, the trackbar is there -- can you find it? ). With the near-equal length of the trackbar and draglink, coupled with the other two factors of parallel and plane, the steering geometry is better than stock. Really. :
skain8 is offline
post #60 of 97 Old 01-27-2014, 04:19 AM
wvracer821
wvracer821's Avatar
why did you choose to mount the tie rod to the drag link instead of the drag link to the tie rod like the picture below? wont this change the toe angle with suspension movement?
DD: 2014 RAM 3500 Megacab Larmie 6.7L Cummins
Junk: 2000 WJ, 4.0L
Build Thread:
wvracer821 is offline
