Axle Shafts, Gerotor Pumps, Clutch Plates,... oh my! Is my front axle a vari-lok? - JeepForum.com
post #1 of 17 Old 07-06-2009, 03:22 PM Thread Starter
99avant
Supposedly, my Jeep has the front Vari-Lok Axle. I have quadradrive, so this should make it so.
I have no proof of this... The jeep is at the mechanics right now having the axle seals replaced. They noted the shafts have grooves on them causing the seals to wear pre-maturely. The axle shafts were replaced a year ago (I did the work, parts from NAPA). This brought up the topic of replacing the shafts, and what ones to get (vari-lok or not). I said it needs the ones for Vari-Lok, but the mechanic says it is an open diff. We looked at it and neither of us see any clutches in there, and the wheels spin like an open diff.
So I have a few questions.
-How can a vari-lok diff be identified from looking at the inside? I can buy the fact that the system is worn out and that is why the wheels spin like the diff is open, but that would not account for the missing guts... What do the gerotor pumps look like?
-Would an axle shaft designed for a vari-lok axle fit into a non vari-lok axle (and vise-versa)? I read that the vari-lok shafts are longer. The axle shafts that I put in are for a vari-lok axle - I just checked the part numbers.
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #2 of 17 Old 07-06-2009, 03:29 PM
ajmorell
ajmorell's Avatar
http://www.wjjeeps.com/varilok.jpg
IIRC the axle shafts are different lengths, and no they aren't interchangeable.
ajmorell is offline
post #3 of 17 Old 07-06-2009, 03:44 PM Thread Starter
99avant
I see, the clutches would'nt be visible from the outside of the carrier? We had the carrier pulled and didn't see anything that indicated it was anything but open. Thanks Andy
99avant is offline
post #4 of 17 Old 07-06-2009, 09:19 PM
ajmorell
ajmorell's Avatar
Yeah, at least that is the way it looks from the picture. I have to be honest, I'm not all that familiar with WJs, let along the vari-lok axles but that is what I would assume as well.
ajmorell is offline
post #5 of 17 Old 07-06-2009, 09:38 PM
StrokedWJ
StrokedWJ's Avatar
What did the carrier look like? The pic below has an open carrier on the left and a track-lock carrier on the right. From looking at the wjjeeps link, the varilock carrier is similar to the track-lock carrier in shape (more squared off).
I thought the vari-lock units would have some type of markings on the case, whether it say vari-lock or hydra-lock. I guess you could also remove the spider gears and see if there's anything behind it...
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #6 of 17 Old 07-06-2009, 09:39 PM
SaturnICL
Varilock axles are different length
SaturnICL is offline
post #7 of 17 Old 07-07-2009, 05:51 AM Thread Starter
99avant
I have to go to the shop this morning to drop off a few things, Ill snag a pic of the carrier.
It has to be a vari-lok, the shafts in there are for a vari-lok.
99avant is offline
post #8 of 17 Old 07-07-2009, 06:22 AM Thread Starter
99avant
Here are a few shots of my carrier from my original rebuild
99avant is offline
post #9 of 17 Old 07-07-2009, 08:18 AM
tsconver
2003 WJ
that is a varilok diff, you need varilok shafts.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #10 of 17 Old 07-07-2009, 09:16 AM
mrese
mrese's Avatar
You could get the numbers off the tag on the axle if it is still there and also your build sheet would say....
if it is a Quadra Drive II it would be Vari-loc front and rear.
Make sure you put the Friction Modifier in if it is a Vari Loc
Mark
Amsoil Dealer
'99 WJ Limited 4.7 K&N Filter CB 3" IRO
302, 000 miles
mrese is offline
post #11 of 17 Old 07-07-2009, 01:55 PM
StrokedWJ
StrokedWJ's Avatar
x2...From looking at the pics thats what it looks like. You can see how the spider gears are offset to the right and the pump/gerotor system is housed on the left. The vari-lock system has to be "primed" before it will activate, basically there must be some wheel slip to produce pressure on the clutch packs from the gerotor and pump, thats probably why it was acting like an open diff during your spin test.
post #12 of 17 Old 07-07-2009, 03:17 PM Thread Starter
99avant
Yep, it is a vari-lok.
Just got it back. Axle seals, Pinion seals, Axle shafts, and some brake pads.
99avant is offline
post #13 of 17 Old 08-11-2011, 11:25 AM
twmart
Does any body have a side by side picture of the Trac-lok, Vari-Lok and open carrier or even 3 separate pictures?
1989 Cherokee
1990 Cherokee
1999 Grand Cherokee
2001 Cherokee
twmart is offline
post #14 of 17 Old 08-11-2011, 12:15 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
google images?
ratmonkey is offline
post #15 of 17 Old 08-11-2011, 12:26 PM
twmart
Originally Posted by ratmonkey View Post
google images?
I know but I am at work and being lazy.......
I will do that when I get home..
1989 Cherokee
1990 Cherokee
1999 Grand Cherokee
2001 Cherokee
twmart is offline
front vari-lok axle problem - IM STUMPED QuadraTokn ZJ Grand Cherokee Forum 20 02-05-2010 12:34 PM
wj front axle shafts JeepWJBob ZJ Grand Cherokee Forum 2 10-05-2009 11:30 AM
ZJ front axle shafts / get rid of cv style??? ASE-MJ ZJ Grand Cherokee Forum 20 11-26-2007 04:28 AM
front zj u-joint axle shafts a direct swap for cv axle shafts? bjl95mustang ZJ Grand Cherokee Forum 12 05-19-2007 05:57 PM
WJ front axle shafts FearTheDentist ZJ Grand Cherokee Forum 5 05-05-2005 10:23 PM
