Awful squeaking noise.. - JeepForum.com
post #1 of 5 Old 11-27-2013, 05:35 AM Thread Starter
sage39henry
Hey guys, the wj is making a pretty loud and annoying squeak. Its only while driving, whenever i am stopped it does not make the noise. It sounds like its coming from the front, almost like a belt squeal but wouldnt that be all the time. But i am not 100% sure where the noise is from. I know i need to replace an axle seal on the driver side rear. Is that the culprit? Driveshaft related? Brakes? I guess i just need a place to start. Thanks for your time. Have a HAPPY THANKSGIVING
WHITE WJ LIMITED 4.7 242HD/ IRO arms w/ Rusty's 4.5in coils/Doetsch 5in Shocks/JKS Quicker Disco's/ D44a Spartan Locker/ Rigid Industries 10" light bar/ 33 12.50 15 Mickey Thompson MTZ/ V-5s
sage39henry is offline
post #2 of 5 Old 11-27-2013, 05:51 AM
marcall
yeah, a belt noise would make it regardless of moving or not. Could be brakes. Take note of when it does it. Does it go away if you lightly apply the brake pedal? Turning to one side, etc?
marcall is offline
post #3 of 5 Old 11-27-2013, 06:15 AM Thread Starter
sage39henry
It gets a little more quiet while slowing down
post #4 of 5 Old 11-27-2013, 06:25 AM
marcall
well the easiest way to eliminate if it's coming from a belt or accessory is to pull the belt and run it, see if the noise goes away.
marcall is offline
post #5 of 5 Old 11-27-2013, 03:01 PM Thread Starter
sage39henry
def not belt. um my ABS light is on though and we have got a lot of snow the past couple days and its doing it for a while but not as loud or as often. ABS light have something to do with it?
