Auto trany slips when making a left turn? - JeepForum.com
 1Likes
post #1 of 28 Old 04-03-2006, 03:23 PM Thread Starter
tom81cj8
Hello, I have a 2000 WJ Select track 4.0L which seems to have a issue when making a left turn. When I make a left turn the auto tranny acts like it is slipping or down shifts down way to low and the RMP's wrap out before the tranny catches again. Almost like a nutral drop at times. Anyone have any suggestions on where to start looking? Is there an issue with the Select track "full time 4 wheel drive" when making a letf turn?
Thanks for any info or help.
TK
tom81cj8 is offline
post #2 of 28 Old 04-03-2006, 03:28 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
The TC has no idea what direction you're turning, only that the front wheels want to spin faster then the rears...
Check the transmission fluid level. Park on level ground after the transmission has warmed up. Put the transmission in neutral and with the parking brake on verify the transmisison fluid level is between the two hot marks on the dip stick...
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 28 Old 04-03-2006, 04:47 PM Thread Starter
tom81cj8
Why I asked about the transmission and turning with full time 4 wheel drive is becuase of the computer controll of the wheel slip. Since all wheels are in drive and yes one wheel turns les the the other while turning would there be a wheel speed sensor type kick down switch or something that would need to be replaced? I see where there is an issue with the cooler return filter replacement and possible simptoms there, but I really only have an issue when turning left? The fluid level is full and new. I did that first thing.
DELAYED ENGAGEMENT DUE TO COOLER RETURN FILTER REPLACEMENT (45RFE / 545RFE TRANS)
Date: 09/01/05
Model year(s): 1999-2004
Description: NOTE: This bulletin applies to vehicles equipped with a 45RFE or a 545RFE automatic transmission (sales code DG4 or DGQ respectively). This bulletin involves a transmission delayed shift condition that may occur following the replacement of the internal cooler return filter.
Details: The customer may experience an initial delayed shift engagement following an extended off (not running) period of time, generally after being parked overnight. The initial shift engagement may feel like a delay or slip when a transmission gear (reverse or drive) is first selected after engine start.
The customer may not have experienced the delayed shift engagement until after the transmission has been serviced, where the cooler return filter was replaced during the service and/or repair.
The condition is not detrimental to the transmission but may cause concern with the customer.
The above condition may be caused by a suspect cooler return filter a part number of 04799662AB. This “AB” suffix / level filter may allow transmission fluid to drain back out of the torque converter. The drain back condition may occur over a period time when the engine (and transmission) are not running. With less fluid in the torque converter a delay in gear engagement may occur at engine start up while the torque converter fills to its proper fluid level.
All 04799662AB cooler return filters with the “AB” suffix are suspect. The above condition may be corrected by replacing a suspect “AB” filter with a new cooler return filter whose part number is 04799662 (with no suffix or with a suffix that is other than the “AB” level).
NOTE: The cooler return filter, p/n 04799662, will not be available until September 09, 2005. The filter part number is stenciled on the side of the filter case.
NOTE: A replacement 04799662 cooler return filter may come packaged with a separate threaded adapter stud. The threaded adapter stud is used to attach the cooler return filter to the transmission. Inspect the stud and note end without threads. Install the stud end without the threads into the cooler return filter and tighten the stud-to-filter connection to 18.6 Nm (165 in. lbs.). Once the threaded adapter stud has been installed to the cooler return filter, install the assembled cooler return filter to the transmission and tighten the filter to 14.1 Nm (125 in. lbs.) Filter location
Anyone have similar issues??
Thanks
TK
tom81cj8 is offline
post #4 of 28 Old 04-03-2006, 04:59 PM
Arkansas_WJ
Arkansas_WJ's Avatar
Yes, happends to me every morning for about 20-30 seconds when i first start out. Only happends in drive though not reverse.
Mitch
2000 WJ Limited - 4.7l, 4x4, pioneer HU w/ ipod interface, upgraded front calipers, yakima lowrider system, uniden cb w/ 4 ft firestick, 3.5" tweeter upgrade
Arkansas_WJ is offline
post #5 of 28 Old 04-03-2006, 05:49 PM
ArloGuthroJeep
Mr. Hyde!
There is no computer control for the 4wd system...it is all mechanical. The only thing monitored is each wheel's speed which feeds into the ABS system for braking and also detects the speed of the vehicle. Neither of which should effect the transmission shifting.
post #6 of 28 Old 04-04-2006, 11:45 AM Thread Starter
tom81cj8
Ok so why will I only have the trany slip when making a left turn and not a right turn? It isn't only when it is cold or first start up. It is all the time. It can happen when crawling along or gunning it? I have an old CJ with lockers and all the fun stuff which I did all the work. I am not new to Jeeps just this new Select track system on a auto trany. This is also my first round with Full Time 4 wheel drive. I thought the point of Full time 4 wheel drive would be to add power to the wheel that slips not just add braking to the other side? am I wrong on this?? Also since both wheel are not locked they will turn at a different rate right? That is why I was asking about making the left turn since it only slip then. Is there some sort of sensor which would adjust this? The filter change seemed like common sense, but I just bought the damn thing and had the trany serviced. It didn't start happening right away but is getting worse as time goes by. Other then adding a new filter again are there any sensors I should be looking at as well?
Thanks
TK
tom81cj8 is offline
post #7 of 28 Old 04-04-2006, 01:59 PM
silvergc
I had exactly the same problem with my ZJ last summer. The problem only occurred after a left turn. It turned out to be the transmission control cable from the throttle body. It was out of adjustment (the transmission fluid was fine BTW). Once adjusted, the problem went away and hasn't returned in over 9 months.
'98 Grand Cherokee Laredo
4.0L, Selectrac
30X9.5 Goodyear Wrangler Silent Armor
1" BB and Kevin's front trackbar kit
Hitch mounted Warn 9000i
silvergc is offline
post #8 of 28 Old 04-04-2006, 02:06 PM Thread Starter
tom81cj8
Silvergc,
Thanks. That is what I am looking for. I will take a look at the adjustment and see if it is out of wack. I'll let you all know what I find out.
TK
tom81cj8 is offline
post #9 of 28 Old 04-05-2006, 03:03 PM
Vivid
Mine happens when I go to a stop. When I let off the brake the tranny clunks into 1st gear. Doesnt happen until it is warmed up. I have a 04 GCL 4.0 with 30k on it.
Vivid is offline
post #10 of 28 Old 04-05-2006, 03:08 PM
ArloGuthroJeep
Mr. Hyde!
An '04's powertrain should still be under warranty
post #11 of 28 Old 04-05-2006, 03:22 PM
Vivid
Yes it is...
I have to take it in this weekend.
Vivid is offline
post #12 of 28 Old 06-01-2007, 06:04 PM
nothinguntil
1987 YJ Wrangler
Don't know if any one will even see this reply but I have been having the same problem. When I take a left turn my RPMS go up and I go no were. I am going to check the adjustment listed and hopefully it will make a difference.
nothinguntil is offline
post #13 of 28 Old 06-01-2007, 06:29 PM
mudgts
mudgts's Avatar
I think what is happening is that like most 4X4's, it's usually the left front and the right rear that have most of the power when driving. If your model has the full time 4X4 quadra-trac then chances are that when you are turning a sharp left, it's the slip in the axle that is causing that hopping feeling or slipping. it's not a bad thing, it should be normal.
to test that theory, find some slippery grass or mud and try it in that condition. See if it happens. If it doesn't then it is due to the fact that the wheel is turning. On a non-slip surface like asphalt, the wheel has too much traction and is causing a hopping feeling.
where is the thread on worst stuck Jeep Compass?
mudgts is offline
post #14 of 28 Old 06-01-2007, 07:10 PM
teenwolf1393
this might mees with ur head. i have a 96 gc 4.0l and mine is doing the same thing BUT i had an aftermarket trans cooler put in when my trans crapped out on me.
teenwolf1393 is offline
post #15 of 28 Old 03-10-2012, 04:51 AM
newtojeeps
Was there a solid conclussion to your problem? I have the same thing happening with an 01
newtojeeps is offline
Engine spits and sputters when making a hard left turn - help vtheory ZJ Grand Cherokee Forum 7 02-09-2009 12:06 AM
95 ZJ rattling noise when making a left turn 95JpZJ ZJ Grand Cherokee Forum 2 07-02-2008 06:56 PM
slipping auto trany subzero32 ZJ Grand Cherokee Forum 10 12-18-2006 03:27 PM
97 Auto Trans slips in 1st or 2nd + won't shift to 4th, TPS or bands? ERICH ZJ Grand Cherokee Forum 14 10-08-2004 06:56 AM
Squeeling In power steering when making a left turn. MFairbourn WJ Grand Cherokee Forum 4 07-31-2002 05:31 AM
