auto headlights - JeepForum.com
post #1 of 7 Old 03-21-2010, 09:58 PM Thread Starter
jdnet
auto headlights
Hi guys,
A new Wj owner here. I owned a dodge intrepid before I totalled it and got my WJ a few weeks ago. I have a questions about the auto headlights in the WJ. In my trep I had the wiring in place and just had to add the sun sensor and the auto headlight switch. I looked at the WJ and there isn't any wiring where the sensor mounts. So my question would be how to to get the sensor and new auto headlight switch to work.
Thanks in advance,
Don
jdnet is offline
post #2 of 7 Old 03-22-2010, 12:14 AM
ZJ5point2GCL
what trim level? laredo?
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #3 of 7 Old 03-22-2010, 12:24 AM Thread Starter
jdnet
2000 laredo
jdnet is offline
post #4 of 7 Old 03-22-2010, 08:10 AM
sontog
I have a 2004 GC, and I think that from 1999 to 2004 the wiring for the the sensor is there.. I installed a Factory set of foglights and it came with the sensor I don't know if jjeeps .com will tell you where the wiring is for the sensor, it would be worth a check, You have to pull the guage cluster out and it is located up to the top inside the dash, you will have to look very carefully to see it I think its taped up at the top, Hope this helps
sontog is offline
post #5 of 7 Old 03-22-2010, 08:16 AM
LordHobbit
That should be wjjeeps.com Jeep Grand Cherokee WJ - Auto headlamps and headlamp alignment this should give you some info
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #6 of 7 Old 03-22-2010, 10:50 AM Thread Starter
jdnet
I never looked inside the dash. Just the top. I guess I will have a look at that in a little bit. Thanks for the info.
BTW. Got another question. I bought a whole steering colum and it came with steering wheel controls. Would the controls work once I put the new clock spring in?
jdnet is offline
post #7 of 7 Old 03-23-2010, 01:24 AM Thread Starter
jdnet
Thanks, Sontog. I looked under that dash and found the harness for the sun sensor. Pluiged it in and my auto headlights work now. The only thing I didnt get to yet is installing the clock spring for radio controls and the auto dimming mirror. Oh yeah I love how the guys at the salvage yard refused to believe me when I said I could hook up auto headlights and steering wheel controls into a jeep without them. I've done it plenty of times with intrepid and I don't see why it cant be done with a jeep.
jdnet is offline
08 GC Auto Headlights bilbo_28 WK Grand Cherokee & XK Commander Forum 6 03-31-2010 08:14 PM
Auto Headlights rolls101 WK Grand Cherokee & XK Commander Forum 6 02-14-2008 04:16 PM
Auto Headlights PolarisCobra WK Grand Cherokee & XK Commander Forum 2 10-27-2007 06:11 PM
Auto Headlights Bloodbath ZJ Grand Cherokee Forum 2 03-29-2006 10:19 PM
Add on auto headlights? 99TJSport ZJ Grand Cherokee Forum 1 03-24-2005 02:31 PM
