Auto closing sunroof - JeepForum.com
post #1 of 18 Old 06-03-2014, 02:28 PM Thread Starter
BrianBSHS
Any know what it would take to make the sunroof auto close? Also perhaps looking it up to rain sensor so it auto closes if it starts to rain?
2004 Onyx Green Overland 242HD
4.5" Clayton long arm kit + 35" Duratracs
Instagram: @_brianb
BrianBSHS is offline
post #2 of 18 Old 06-08-2014, 12:41 AM
tuglife
You mean like an auto close when shutting off the vehicle? Sounds complicated. Turning the key off cuts power to your electrics so that would have to be bypassed so it would continue to close after the key was removed. Then you'd need some sort of signal to close it when switching to ACC I'd imagine.
The rain sensor is an interesting idea and possible if you have rain sensing wipers (which never seem to work that well). Problem is mine at least take a decent amount of water to come on. It appears it's the motion of the droplets across the sensor that activates it. Imagine in that time I'd be wet and annoyed and will have shut the sunroof manually. If you're talking about it auto closing due to rain while the vehicle is sitting well you'd need to invent a way to auto predict bird **** and once you've done that well you're now a millionaire and won't be driving a WJ anyway. Good luck.
,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,2004 WJ Overland ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
4.7 HO V8, K&N FIPK, Old Man Emu HD Springs, Bilstien 5100, 31" 255/70/17 Bridgestone Dueler A/T Revo 2, Black JK Moabs, Overland Rock Sliders, Tow Hooks, Westin Brush Guard, GTP Hood Vents, Mopar iPod Integration Kit
tuglife is offline
post #3 of 18 Old 06-08-2014, 01:22 AM
bradywgn71
bradywgn71's Avatar
Maybe this would work?
http://www.amazon.com/Install-Essent...m_cr_pr_sims_t
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline
post #4 of 18 Old 06-08-2014, 05:52 AM
Darnice
Actually turning off the key does not cut the power to the accessories, like power windows and sunroof. They stay active for 30 seconds after you remove the key or open a door, which ever comes first.
As for the power roof close automatically, probably more work that it worth.
Darnice is offline
post #5 of 18 Old 06-08-2014, 08:25 AM
drmadcat
2006 WK
My 02 auto closes when i turn the key off.
drmadcat is offline
post #6 of 18 Old 06-08-2014, 02:36 PM
imaguy3
weird b/c my 04 doesn't
EvilEagle - "Imaguy3 just made everyone in this thread his *****."
imaguy3 is offline
post #7 of 18 Old 06-08-2014, 04:47 PM
tuglife
Mine either. Betcha it's a evic option that got the axe after some kids head got chopped off.
tuglife is offline
post #8 of 18 Old 06-08-2014, 04:52 PM
Jaspah
Mine doesn't. Sounds like its something aftermarket.
Jaspah is offline
post #9 of 18 Old 06-08-2014, 08:48 PM
narnwv
narnwv's Avatar
Scroll through your EVIC up top and see if you can turn that on or off. I've never heard of that before, and would want the control over it.
~Aaron
narnwv is offline
post #10 of 18 Old 06-08-2014, 09:12 PM
rdkendrick
2003 WJ
I have never seen "sunroof" in any of my EVIC's, but will have to try the automatic closing when I turn off my Jeep.
Sent from my iPad using Electrons
rdkendrick is offline
post #11 of 18 Old 06-08-2014, 09:16 PM
narnwv
narnwv's Avatar
I haven't either, which is why I asked them to check.
Mine doesn't close when I turn off the Jeep. I've been rained in a few times. If it did, there would have to be an option to turn that off, as sometimes I like to leave it open with the Jeep off.
~Aaron
narnwv is offline
post #12 of 18 Old 06-08-2014, 11:38 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
The auto-close is on laredos with sunroofs. Not sure why it's a different system on limiteds.
Sent from inside my dinosoar head.
~James
ezflip is offline
post #13 of 18 Old 06-09-2014, 12:43 AM
cuttysark
My 04 limited auto closes
cuttysark is offline
post #14 of 18 Old 06-09-2014, 06:45 AM
cde02ltd
Our 02 limited does not auto close. Would be nice if it did! Or at least one touch close would be nice. It has one touch open, why not close? I have owned it since new, and I don't recall it being a setting in the evic.
cde02ltd is offline
post #15 of 18 Old 06-09-2014, 07:11 AM
Trav1s
My '04 Columbia (which is essentially a Laredo) does not auto-close. I have not found anything in the EVIC either. I just looked on www.wjjeeps.com and could not find anything either.
04 Columbia Ed 4.7 HO/QTII/SSD107/UC/Bilstein 4600/RB4/Moabs/Cooper Discoverer AT3's/PML trans pan
Trav1s is offline
