Archive of ArloGuthroJeep’s Front Axle Shaft/wheel bearing assembly write-up - JeepForum.com
 6Likes
  • 2 Post By mtsgsd
  • 1 Post By FPKites
  • 2 Post By alfaitalia
  • 1 Post By HarryH3
post #1 of 10 Old 03-25-2016, 09:52 PM Thread Starter
mtsgsd
Originally posted by ArloGuthroJeep
After a day of fun you Jeep may look like this:
On my Jeep I have aftermarket wheels so I am able to access the main hub nut with the wheel still on.
Start by removing the cotter pin:
Then the cap:
And behind the cap is a spring (shown on left):
Next, use your trusty 36mm socket to break that nut before you take off the wheel:
With the nut torqued to 175ft/lbs and rust/dirt seizing up the nut, i t isn't a surprise that a cheater bar helps In this case it is my old tie rod.
Now jack up your axle:
And remove the wheel , place it under your sliders if you have them or under your hub in the event your Jeep falls off the jack, it won't crash onto the ground:
Next, remove the caliper bracket (2 x 18mm bolts) and hang it from the spring via wire or zip ties:
Next, on the back side of the knuckle there are three bolts. They require a 12pt 13mm socket to remove them and can be stuck on there pretty good as well . The first one is at the top, then the
other two are on the lower left and lower right (imagine a triangle):
mtsgsd is offline
post #2 of 10 Old 03-25-2016, 10:06 PM Thread Starter
mtsgsd
Continued:
At this point you can remove the hub. In my case the outer axle shaft came out with it since I blew up the joint:
This leaves you with steering knuckle, minus the outer axle shaft:
Remove the inner axle shaft and replace:
When putting everything back together there isn't anything special to do.
  • Torque the 3 12 pt 13mm hub bolts to 75 ft/lbs.
  • Torque the main 36mm hub nut to 175 ft/lbs.
Tricks/suggestions:
  • If you don' t have a wheel where you can get easy access to the big hub nut to break it, remove the wheel, and then have someone apply the brake while you loosen the nut.
  • Some of the ABS cables get in the way, just remove them from the bracketry and push them to the side when getting to the hub bolts.
  • If available, be sure to use PB Blaster on the bolts/nuts i f they haven't been removed in a while. Last thing you want to do is snap a bolt!
  • My only other hint to this procedure is that i t is easier to get to some of the bolts if you turn the wheel to either side.
Ok, I installed a new axle shaft today. After Napa shipped in an axle with busted tone rings, I picked up a remanufactured unit for $116 after tax. New units are cheaper then remanufactured units (go figure) but they couldn't get a new one until Thursday and work doesn't like me working from home all the time
New axle shaft:
Review what we have here to put back on, Cotter pin, castle washer, spring washer, axle**-->hub nut, washer, 3 hub nuts, and a socket that doesn't belong in the picture. What is missing? The two
bolts holding on the caliper bracket to the knuckle.
When you slide in the new axle, make sure the splines are clean (as they go into the diff and we want to keep that fluid clean), and try not to let it touch the inside of the axle tube much since it is dirty in there.
Toss on the hub and bolt it back up, remember these three bolts require 75 ft/lbs of torque.
Install rotor and brake caliper:
Then reinstall the tire and torque hub**-->axle nut to 175ft/lbs:
Polydiene and Sprung99GC like this.
mtsgsd is offline
post #3 of 10 Old 03-26-2016, 12:33 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Great job!
Made this post a sticky to keep it up top
Polydiene likes this.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #4 of 10 Old 03-28-2016, 06:29 AM
alfaitalia
Great info.................but don't just rely on a jack to hold ANY up vehicle you are working on. Axles stands are a must.....be safe out there kids!
johnboulderco and JRobes like this.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #5 of 10 Old 03-28-2016, 05:36 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Hey...that was almost 10 years ago. Kids were barely wearing helmets to ride their bikes
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #6 of 10 Old 03-29-2016, 07:13 AM
ChrisHager
Administrator
ChrisHager's Avatar
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #7 of 10 Old 03-29-2016, 08:43 AM
alfaitalia
Helmets.............on pedal bikes??? Haa haa You Americans are so funny!
post #8 of 10 Old 06-07-2016, 12:38 AM
lacofdfireman
This is my next project.
Sent from my iPhone using Tapatalk
lacofdfireman is offline
post #9 of 10 Old 06-07-2016, 08:33 AM
HarryH3
Suggest changing the title of this thread to include the word "Front" to specify which axle shaft.
EDIT -> Thanks Mods!
mentalben likes this.
HarryH3 is online now
post #10 of 10 Old 04-14-2017, 09:19 AM
ggullifordjr
Im about to do this project on my 01 laredo with select trac. This is a great write up and appreciate the info, my only question is this, is greasing the spline on the axle shaft before installing it recommended? Ive seen multiple videos on this and some do and some dont. Is there advantages to greasing it, and whats the correct grease to use? Im just putting in aftermarket axles and hoping they last me atleast a year while i fix some other things and save up to get the RCV Ultimate Dana 30s.
ggullifordjr is offline
