Anyone using JKS BPE's with Bilstein's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Anyone using JKS BPE's with Bilstein's?
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 12-21-2011, 08:13 AM   #1
ChrisHager
ChrisHager's Avatar
I received my Bilstein 5100/5125's yesterday! A member on the forum sold me a new set of JKS Bar Pin Eliminators so I was wondering if anyone is using these with bilstein shocks. I know the bar pin on the shocks is pretty good but I figured I might as well use the eliminators since I got a good deal on them.
Also, how the heck do you get the original bar pins out? They are SNUG! Do you just pound them out with a hammer?
Thanks!
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift - Build Thread
His: 1979 J-10 - 3" on 33s - Build Thread
His: 2009 Expedition
Hers: 2000 TJ
Hers: 2010 Jetta
ChrisHager's 'Grilled' Thread
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline   Reply With Quote Quick reply to this message
Unread 12-21-2011, 08:18 AM   #2
Rocklobster
I would wait till you wear out the stock bushings
Sent directly from my brain using JeepForum
Rocklobster is offline   Reply With Quote Quick reply to this message
Unread 12-21-2011, 09:02 AM   #3
Iron_Rock
Use a bench vice to grab one end of the bar pin and then take a long screwdriver, or a pry bar and pry the shock eye up. Make sure to use grease as a lubricant when assembling the BPE's.
Iron_Rock is offline   Reply With Quote Quick reply to this message
Unread 12-21-2011, 02:15 PM   #4
gtg413i
gtg413i's Avatar
2003 WJ
If you're like me, you don't have a table clamp, so pound them out and pound them in- the green hits the green in the pic. If the bar pins are already installed, I don't see why you would replace them with the BPE as that's more work. The top of the shock mounts a little different, I have some pics in my build thread if you want to double check that installation. http://www.jeepforum.com/forum/f197/...44/index2.html
gtg413i is offline   Reply With Quote Quick reply to this message
Unread 12-21-2011, 02:33 PM   #5
smunns
I use my shop press.
smunns is offline   Reply With Quote Quick reply to this message
Unread 12-21-2011, 03:20 PM   #6
PhantomWJ
2003 WJ
I didnt use BPE's....i sold mine with the old RCX kit.
Is there a need for BPE's?
PhantomWJ is offline   Reply With Quote Quick reply to this message
Unread 12-21-2011, 03:22 PM   #7
skain8
I've used BPE's with shocks other than Bilsteins. With Bils, I have had no clunks.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
Half-Ton axle swap guide
231HD build info
skain8 is offline   Reply With Quote Quick reply to this message
Unread 12-21-2011, 04:21 PM   #8
ChrisHager
ChrisHager's Avatar
Cool thanks for the responses. Unless someone has a great reason to switch, I think I'm going to lean towards using the bilstein bar pins since they are already in there and constructed well. I can always change them over later if they ever start clunking.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
Unread 12-21-2011, 04:33 PM   #9
devinci
using bar pins will give you a bit more down travel too (0.5"???)
devinci is offline   Reply With Quote Quick reply to this message
Unread 12-22-2011, 12:42 AM   #10
RobertTF
I'm not using bpe's with my Bilsteins. Tried removing the bar bins and without the right tools there was no way I was going to do it without pushing the bushing out or ruining it entirely.
2001 4.7l Limited WJ
IRO 6.5" Critical LA, Lonestar Incline Bumper, XRC-8000 Comp Winch, 33" BFG All-Terrains, and a long list of other stuff.
RobertTF is offline   Reply With Quote Quick reply to this message
