Anyone in the Cincinnati, Dayton, Northern Kentucky area???? - Page 2 - JeepForum.com
post #16 of 34 Old 03-15-2010, 03:55 PM
ras2001wj
ras2001wj's Avatar
My 2001 is in getting a jy transmission right now for the same symptoms. Mine broke a snap ring that retains the pressure plate.
Good luck
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
ras2001wj is offline
post #17 of 34 Old 03-15-2010, 03:59 PM Thread Starter
Jeepgirl2010
How do you feel about this advice? But in my case the trans temp light is NOT coming on.
"There are a couple possible causes for your problem. One would be and electrical problem with the trans, likely with the governor pressure transducer or it's wiring. This is mounted to the right side of the valve body in the trans. It also acts as the transmission temperature sensor. If the governor pressure transducer fails it will definitely cause problems with shifting, and it can also turn the trans temp light on when the fluid isn't actually overheating.
The other possible cause would be that the trans is actually overheating. It would start by turning on the overdrive off light and locking out fourth gear, and would progress to the trans temp light coming on. This would most likely be from a plugged trans cooling system, whether it's in the cooler in the radiator or the torque converter drainback valve in the pressure line. This is a check valve that can get plugged or stick closed. If the cooler is plugged there will be no cooling so it will give the lights you saw, and it can also cause line pressure to drop off far enough that there will be no shifting out of first gear."
Jeepgirl2010 is offline
post #18 of 34 Old 03-15-2010, 05:10 PM
stratons_yj
I forgot about the governer pressure sensor...a very very common problem on the 6 cylinders.
I still dont know too much about the 6 cylinder unfortunately....there are a lot of people who have had this problem and I wish they would chip in on it.
stratons_yj is offline
post #19 of 34 Old 03-15-2010, 05:16 PM
ras2001wj
ras2001wj's Avatar
How many miles do you have?
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
post #20 of 34 Old 03-15-2010, 05:29 PM Thread Starter
Jeepgirl2010
Around 150K give or take.
post #21 of 34 Old 03-15-2010, 05:31 PM Thread Starter
Jeepgirl2010
Yea i kinda figured this was a common problem, I should have titled the thread differently to get more input. Oh well.
Is the pressure sensor hard to replace?
post #22 of 34 Old 03-15-2010, 05:32 PM
joburocks
Wouldn't hurt to toss a message up at the regional forums either.
South East USA- (VA, KY, TN, NC, SC, GA, FL, PR, AL, MS, VI)
would be my first choice.
or
Great Lakes USA - (WI, IL, IN, MI, OH)
Wish I had some technical stuff for you on the trans, but they are the great mystery to me. Good luck, hope you don't need a new one.
joburocks is offline
post #23 of 34 Old 03-15-2010, 05:36 PM
ras2001wj
ras2001wj's Avatar
Unfortunately that is a pretty long life for a stock 42re and without dropping the pan to see what it looks like in there, it is hard to tell if it's worth throwing parts at.
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
post #24 of 34 Old 03-15-2010, 05:41 PM
ras2001wj
ras2001wj's Avatar
Your symptoms sound extremely similar to what mine was doing, and with 9 months of damage done (I did it for 4 months), I would guess that you would face replacing hard parts, whereas a junkyard transmission may be your best bet if the mileage is low enough.
If I weren't almost 3 hours north of you, I would gladly help, but I'm in the same shoes and just scraped $600 together to get my transmission replaced just so I could get back to work.
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
post #25 of 34 Old 03-15-2010, 07:14 PM Thread Starter
Jeepgirl2010
Well thanks for the offer. Did you get your new trans at a junk yard and have a shop put it in?
post #26 of 34 Old 03-15-2010, 10:07 PM
ras2001wj
ras2001wj's Avatar
My mechanic is doing it for me. I drove down to ****'s auto salvage in Findley when I found a trans for $235 with only 55k out of an 04.
Well, the timing of me finding it on time couldn't have sucked more, my mechanic left to go to Florida with my Jeep on the lift, but being a one man operation, I'm getting it back after a weeks wait tomorrow.
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
post #27 of 34 Old 03-15-2010, 10:46 PM
ras2001wj
ras2001wj's Avatar
is a semi-common first name really that bad?
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
post #28 of 34 Old 03-16-2010, 04:06 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Is your check engine light coming on at all? Like during the start up check?
Get the codes, autozone will check them for you. Post what you get.
The temp/gov pressure sensor is a common failure. You should replace the solenoid too. Its an easy fix if nothing hard has been damaged. You should have the cooler line check valve removed and the cooler flushed as well.
The sensor is staring you in the face when you drop the pan. You need the same tools to replace it as you do to change the filter.
After nine months I'd expect that trans to drop a 10lb baby on you soon. (or a similar sized rebuild bill)
ratmonkey is offline
post #29 of 34 Old 03-16-2010, 06:48 AM Thread Starter
Jeepgirl2010
No the check engine light isn't coming on at all. I will attempt to drive to autozone and see if a code pops up anyhow.
Thanks for the advice, where would you suggest buying a new solenoid, and temp/gov pressure sensor? Also, where and what brand of cooler fluid should I buy after flushing the system? Should I get it all at autozone?
"After nine months I'd expect that trans to drop a 10lb baby on you soon. (or a similar sized rebuild bill)"
Are you saying that when I drop the pan, I am going to find a heap of metal shavings and whatnot?
post #30 of 34 Old 03-16-2010, 12:16 PM
ras2001wj
ras2001wj's Avatar
The cooler just cools the transmission fluid. Buy only ATF 4
I don't know if Auto Zone sells the sensors at all, you may have to order one online or find a transmission parts supplier.
Some metal shavings are fine, but a lot aren't good.
Rick
2001 WJ Laredo 4.0
2" BB
245/75R16
Ron Paul
2012
"Freedoms Popular"
Going to take the fam to "Moody Hill" tomorrow, anyone want to meet? (Northern CO) dickensheets ZJ Grand Cherokee Forum 4 10-27-2008 07:56 PM
WJ Heater core leaking, need a good WJ mechanic in Northern NJ Chomot ZJ Grand Cherokee Forum 2 04-12-2008 05:51 AM
Grand Cherokee drivers in Northern Colo? RAAB3485 ZJ Grand Cherokee Forum 3 07-25-2005 06:32 PM
Any Grand cherokee owners around Cincinnati?? CinciSurWJ ZJ Grand Cherokee Forum 5 07-25-2005 04:38 PM
Places to go Off Road in Northern NJ? njhunter47 ZJ Grand Cherokee Forum 3 07-28-2004 05:17 AM
