Anyone in the Cincinnati, Dayton, Northern Kentucky area???? - JeepForum.com
post #1 of 34 Old 03-15-2010, 11:35 AM Thread Starter
Jeepgirl2010
Anyone in the Cincinnati, Dayton, Northern Kentucky area willing to help me diagnose my transmission troubles. My OD will not turn on, and it won't shift out of first until about 4500 rpms. I checked the trans fluid it was horribly low, so I filled it back up, it ran just fine for a day then back to the same problems. Also, a repair shop said the my trans temp sensor is out. This has been going on for 9 months, but has finally turned for the worse.
I was hoping someone with expertise could come look at it and give me advice. I am on a very tight budget.
Thank you!!!
Jeepgirl2010 is offline
post #2 of 34 Old 03-15-2010, 01:08 PM
stratons_yj
Thank you!!!
Sounds like a speed sensor.....do you have a 6 cylinder or 8?
stratons_yj is offline
post #3 of 34 Old 03-15-2010, 01:43 PM Thread Starter
Jeepgirl2010
Thank you for the reply, it is a V6. 2001 Grand cherokee
post #4 of 34 Old 03-15-2010, 01:45 PM
WJ-matt
Do you mean inline 6
Dude i think i know what your noise is...your jeep is telling me i need a beer....and your gonna need a bigger wallet.
- www.rcoverload.com
WJ-matt is offline
post #5 of 34 Old 03-15-2010, 02:20 PM Thread Starter
Jeepgirl2010
4.0L L6 It's the limited. Is that the inline 6??
post #6 of 34 Old 03-15-2010, 02:28 PM
WJ-matt
For engines jeep made(for that model) either the 4.0L inline 6, 4.7L V8, or the 5.2L V8 im gunna guess that if you have a six cylinder its the inline six 4.0L. Not a V6
WJ-matt is offline
post #7 of 34 Old 03-15-2010, 02:40 PM
stratons_yj
No 5.2's in a WJ...
post #8 of 34 Old 03-15-2010, 02:41 PM
stratons_yj
Is your cladding the same color as your jeep or is it grey?
post #9 of 34 Old 03-15-2010, 02:43 PM Thread Starter
Jeepgirl2010
2001 Jeep Grand Cherokee | Overview of Used 2001 Grand Cherokee Cars at Automotive.com
The website above states that it is a 4.0L L6.
Thanks for the responses, any ideas of what it could be? I have read that if it is the speed sensor that it can be easily fixed. And that the part cost around $20??
post #10 of 34 Old 03-15-2010, 02:48 PM
stratons_yj
A quick way that you can tell if it is a V8 or I6 is open the hood up and if there is a large black rectangle box that says "4.7 V8 Power Tech" than its a V8.
And yes it a very simple fix if that is it....one bolt holds it in and a wire connector....tops 10 minutes to change out.
post #11 of 34 Old 03-15-2010, 02:52 PM Thread Starter
Jeepgirl2010
My jeep is the dark blue color and its the I6 sorry about the confusion. So besides it possibly being the speed sensor is there anything else that I should do/check/replace?
post #12 of 34 Old 03-15-2010, 02:53 PM
stratons_yj
Do you have a check engine light on?
post #13 of 34 Old 03-15-2010, 03:00 PM Thread Starter
Jeepgirl2010
No check engine light is not on, or does not come on. I had it in the shop not too long ago and they mentioned that my Trans temp gauge is faulty and needs replaced?? could that be a reason?? Is that easily replaced as well?
post #14 of 34 Old 03-15-2010, 03:13 PM
stratons_yj
Hmmm....I know a couple guys who have had to replace the speed sensor but they knew that was it because thats what the code was.
I dont think Grand Cherokee's have a trans temp gauge, I know there is a light to warn you of the trans temp...but no gauge (somebody correct me if I'm wrong).
I would go to an Auto Zone or O'Reilly (Or one of the numerous auto parts places) and ask them to run a scanner to see if there is a code
post #15 of 34 Old 03-15-2010, 03:54 PM Thread Starter
Jeepgirl2010
I will try but I can't drive over 35 - 40 Mph and the trans is over heating I believe. How do you post pictures??
Going to take the fam to "Moody Hill" tomorrow, anyone want to meet? (Northern CO) dickensheets ZJ Grand Cherokee Forum 4 10-27-2008 07:56 PM
WJ Heater core leaking, need a good WJ mechanic in Northern NJ Chomot ZJ Grand Cherokee Forum 2 04-12-2008 05:51 AM
Grand Cherokee drivers in Northern Colo? RAAB3485 ZJ Grand Cherokee Forum 3 07-25-2005 06:32 PM
Any Grand cherokee owners around Cincinnati?? CinciSurWJ ZJ Grand Cherokee Forum 5 07-25-2005 04:38 PM
Places to go Off Road in Northern NJ? njhunter47 ZJ Grand Cherokee Forum 3 07-28-2004 05:17 AM
