Anybody undercoating? - JeepForum.com
post #1 of 9 Old 11-04-2013, 09:18 AM Thread Starter
scottwpa
Anyone plan on applying some sort of protection from the salty roads? If so, what and how well does it work for ya.
scottwpa is offline
post #2 of 9 Old 11-04-2013, 09:51 AM
MadderThanMax
Strip it back, bare metal, treat any rust, Epoxy 121, Tetrosyl Stone chip on to followed by Waxoyl and 5 years later looks the same as Day 1 !! Nae Worries!!
MadderThanMax is offline
post #3 of 9 Old 11-04-2013, 11:54 AM
Darnice
What he said, if its a 2001, just covering up the rust with undercoating won't do any good. If it was not coated from new, then you have to fix the rust, then coat
Oil sprays are not too bad, to stop the spread, but you have to repeat it because it wears off.
Darnice is offline
post #4 of 9 Old 11-04-2013, 12:18 PM Thread Starter
scottwpa
This would ideal for a frame up restoration. I guess the term "undercoating" wasn`t exactly what I should have said. Anyone heard of using bar and chain oil as a method to keep the salt at bay?
scottwpa is offline
post #5 of 9 Old 11-04-2013, 05:30 PM
Turbozcs2003
Well
You can do something proactive, go to eastwoods and buy a few qts and aerosol cans of Rust Encapsulator, and chasis black epoxy paint. Also get some Rust converter.
Wash the underside of your jeep, simple green and a brush and some beer for you works well.
Get it as clean as possible, the use the converter on any heavily rusted areas.
Then top coat with the Rust encapsulator every where, then coat with the chasis black.
Lastly they aslo have a heavy duty anti rust which is a heavy wax coating spray that on last.
You could also buy some of their interior frame coating, spray that inside the subframes and rocker panels, they come with a flexible wand.
Lastly buy some Eureka FLuid film and flood all your doors, hatch and nooks and crannies with that, it will run and drip out but keep the moisture and rust at bay.
Turbozcs2003 is offline
post #6 of 9 Old 11-04-2013, 07:40 PM
86cj74.2L
86cj74.2L's Avatar
Fluid film at autozone works good as a light oil spray.
Or a can of stabol fogging oil.
86cj74.2L is offline
post #7 of 9 Old 11-05-2013, 12:32 AM
Uniblurb
Uniblurb's Avatar
I'm in the process of doing an underside rust restoration project on my 2004 in the below thread using the Eastwood products. Have only done the inside/outside rockers using their internal frame coating as can be seen in the photos. Also refurbished the running boards and have a few other outside/house projects slowing me down. I best hurry it up if I'm going to beat the cold/wet weather.
http://www.jeepforum.com/forum/f310/...l#post17084914
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is online now
post #8 of 9 Old 11-05-2013, 03:04 PM
Bandit84
I'll soon be investing in some Fluid Film, I've heard nothing but great things about it.
85' CJ7
Bandit84 is offline
post #9 of 9 Old 11-05-2013, 04:55 PM
Thomahawk
Can highly recomend this shhhh 2 step, penetrering oil/fluid + thicker shh fluid thinghy
http://www.dinitrol.co.uk
Repeat every 3-5 years, fill all cavities, doors, rockers, everywhere,,, did this with my 00 WJ, when i bought it rust free, had it redone after 3 years, Jeep was 98% rust free, 2% front axle lower spring perch when wrecked recently, and here in Norway they really salt the H out of the roads
Buildthread
Thomahawk is offline
