Any Good Foggy Headlight Write-Ups? - JeepForum.com
post #1 of 10 Old 03-25-2010, 10:21 PM Thread Starter
steveridesli
Sorry for making a new thread of a fairly popular issue, but i did so much searching of write-ups and how-to's, but all the threads i found were just showoffs! lol, are there any good write-ups on clearing up foggy headlights?
i was thinking of going the 1000 grit then 2000 grit method. Is it self explanitory to take off the headlights and put them back together?
edit**
NVM! Found one!
http://www.jeepforum.com/forum/f13/w...al-mod-494045/
Do i really have to stick my headlights in the oven in order to remove the plastic bulb colvers to sand the inside? will sanding only the outside do any good?
steveridesli is offline
post #2 of 10 Old 03-25-2010, 10:43 PM
93zjer
I used blue magic lens restorer on both my ZJs and it restored the lenses to perfectly clear! i had already tried a bunch of diff. polishing compounds and a DA sander before that with minimal results. I got it at kragen/oriely parts store. i can post after pics but i dont have any befores.
93zjer is offline
post #3 of 10 Old 03-25-2010, 11:45 PM
ZJ5point2GCL
yeah the blue magic is amazing, i tried wet sanding the headlights on my car up to 3000grit, but its still a little could, but the one i just used blue magic is amazing.
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #4 of 10 Old 03-25-2010, 11:54 PM
kwellzz
half way down:
http://www.jeepforum.com/forum/f13/w...index1471.html
Denver Motorcycle Repair
kwellzz is offline
post #5 of 10 Old 03-26-2010, 05:13 AM
rritch
Originally Posted by kwellzz View Post
That was my posting. I used the 3M headlight restoration kit and it did a great job. Took about 20 minutes per light to do. The kit was $25 at Autozone which is a whole lot cheaper than buying new ones. Here is a picture of the front after it was done. As you can see they are as clear now as the glass lens Hella's. Well worth the little bit of money and time if you ask me.
98 ZJ 5.2L Limited, 2.25" Budget Boost, 31x10.5x15 Definity Dakota MTs, Westin Safari Bar, Hella 500 Driving Lights.
rritch is offline
post #6 of 10 Old 03-26-2010, 09:49 PM Thread Starter
steveridesli
to use the polishes, did you guys have to heat up the headlights and pry out the front piece to get the inside? or did it do just fine only on the outside?
post #7 of 10 Old 03-30-2010, 07:11 AM
rritch
In my case all I did was polish the outside of the lens. If you have moisture etc inside I am not sure what the solution would be.
rritch is offline
post #8 of 10 Old 03-30-2010, 08:30 AM
Technohead
Normally I would just recommend buying replacements from 4WD Hardware. Certainly better than wasting alot of time and elbow grease. I just checked the prices and could not believe it! You WJ guys are getting screwed compared to us ZJ guys.
-Eric
Technohead is offline
post #9 of 10 Old 03-30-2010, 09:39 AM
Double E
Double E's Avatar
For the difference in looks of the headlights as new from the ZJ to WJ, I'll happily take that screwing.
Replacements really are nice if you have more $ than time with 0 concern that they'll cloud back over again.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is online now
post #10 of 10 Old 03-30-2010, 07:08 PM
93zjer
the inside of mine were perfectly fine.
93zjer is offline
Is there a good write-up that explains how to replace CPS? madmax ZJ Grand Cherokee Forum 2 08-26-2008 09:52 AM
Kolak headlight small write-up KingPrat ZJ Grand Cherokee Forum 0 11-09-2007 02:48 PM
Foggy Headlight Buckets, How to Fix? fracdj ZJ Grand Cherokee Forum 8 02-05-2007 06:19 AM
whats a good write up for a 2" BB?? mailforjon ZJ Grand Cherokee Forum 8 11-14-2005 08:25 AM
good bright headlight bulb for 98 zj kemicalburns ZJ Grand Cherokee Forum 9 02-09-2005 11:42 PM
