Another losing water thread. - JeepForum.com
post #1 of 13 Old 06-08-2013, 08:02 AM Thread Starter
rustysjeep
2000 Jeep grand Cherokee Laredo 6 cylinder. I have been losing water for the last 3 years. Adding water no and then. Never any water in the oil or on the oil fill cap. It seems to have gotten worse lately.
What could be the problem and how hard is it to change the head and or gasket.
rustysjeep is offline
post #2 of 13 Old 06-08-2013, 08:14 AM
Terminal
Yeah, those symptoms happened to me a few years ago, too. It turned out it was the radiator slowly leaking steam under pressure, but wasn't apparent for quite some time until it separated enough to be seen squirting raw fluid everywhere and now an obvious steam cloud . There was a split in the seal where they crimp the plastic ends to the aluminum part of the radiator from the factory. Ultimately a new radiator fixed that problem for me, but as always, everybody's mileage will vary.
It didn't take me that long to replace, about a couple of hours and it wasn't that bad. You could to it within an hour if you hustle.
Terminal is offline
post #3 of 13 Old 06-08-2013, 06:41 PM
R0CKKR4WL3R
Had my WJ for a year now, over time I noticed a periodical whisp of steam from under the hood. Recently blew the radiator in it, with a 10" crack down the driver's side. I have reason to believe that there may have been a crack and it created the weakest point in the radiator, as although running hot, it never actually hit the red zone of the gage.
After going backwards down the line, I realized after swapping out the radiator, the fan motor was dead, and once replacing that, the fan was stuck in the "on" position even after the ignition was off. So once I replaced the relay, I came to the conclusion the relay kept the fan on, which burnt out the motor and eventually blew the radiator. The temp that day in particular was 93-degrees and I was stuck in traffic. How convenient...
So yes, without a doubt, there has to be a crack/ slow leak in the radiator. My overflow bottle was ALWAYS empty and "Low Coolant" alarm was always on until I refilled it.
R0CKKR4WL3R is offline
post #4 of 13 Old 06-14-2013, 12:19 PM Thread Starter
rustysjeep
I lost about half gallon in 6 days and noticed the inside of the oil cap on the valve cover has a little water on it. The dip stick is clean, no traces of oil.
post #5 of 13 Old 06-16-2013, 07:54 AM
Jaspah
I'm also losing coolant, but at a very slow pace so far. I top off the coolant reservoir probably every other month or so. My oil is clean and I have no signs of froth or a milkshake mixture, nor has the shop said anything upon changing the oil last time I went.
It visibly leaks when I am parked with the front higher than the rear, but not when it's on a level surface. I'm thinking about adding a UV dye to it and seeing if I can find the leak that way. :\
Jaspah is offline
post #6 of 13 Old 06-22-2013, 10:31 AM
jpaytoncfd
The dip stick has no traces of OIL!!! THat might be your problem. lol.
Anyway, I had the same Radiator problem. Let it warm up and watch your radiator carefully. Do it where there is no wind and remove the fan relay. Then just look for steam. Sometime doing it in the dark with a flashlight makes it easier to see the steam.
jpaytoncfd is offline
post #7 of 13 Old 06-22-2013, 10:32 AM
jpaytoncfd
PS watch your temp gauge carefully while doing this. Running with out the fan can over heat if your not careful.
post #8 of 13 Old 06-22-2013, 05:05 PM
Jer-Bear
Jeeps are bad about condensation at start up if you only drive them a few miles. I'd be concerned if it looked like that after it was driven awhile. Sounds like a cracked radiator to me.
/ 2002 WJ 4.7 H.O. / Flowmaster 50 SUV / Magnaflow Cats / Rocking that 2WD! /
Jer-Bear is offline
post #9 of 13 Old 06-24-2013, 05:37 PM Thread Starter
rustysjeep
I meant no traces of water on the dipstick, no oil would be a problem.
post #10 of 13 Old 06-24-2013, 05:42 PM Thread Starter
rustysjeep
It will get up to running temp. I haven´t really gone that far with it recently. Probably 5 miles at a time. I just checked it before, I drove it a few times the other day and it had some condensation under the cap. The oil level was the same and the oil was fine, it looked like oil with about 3k on it. I am going to change it this week sometime.
post #11 of 13 Old 06-25-2013, 02:59 PM
BIGBADWOLF
Do a blot test before changing oil. 2 drops hot oil from dipstick onto a business card. Glycol can be detected with this method.
BIGBADWOLF is offline
post #12 of 13 Old 06-25-2013, 08:30 PM
Sweetjackal
I've noticed a similar loss I coolant. I get the "coolant low" warning every couple months. I just keep topping it off. Occasionally I get a small puddle of coolant on the pavement under the passenger side near the rear of the engine bay near the firewall.i also have some coolant sludge/wetness on the passenger firewall under the carpet. I feel like it could bee heater core. But the leak is slow In my case. Worth a double check for you
99 XJ – SOLD
00 WJ – Rust Bucket SOLD
01 WJ – 4.7, 247, Zone 4” Lift
Sweetjackal is offline
post #13 of 13 Old 06-26-2013, 07:22 AM Thread Starter
rustysjeep
Changed the oil today, no water or anti freeze in it. Started the truck with the new oil....40PSI at idle.
