Another Drive Shaft Question - JeepForum.com
post #1 of 10 Old 03-13-2014, 12:57 AM Thread Starter
ackliant
I have a 2000 gc with a 2" BB and upcountry suspension. I'm having the all to familiar grinding noise when i'm in 4wd. After doing alot of research on it, I first needed to find out what kind of drive shaft joints I had since the double cardan mod sounded like something I wanted to do.
Unfortunately... I discovered I had rzeppa joints on both ends
But as I was checking things out, I noticed that the boots seemed undamaged and there was no play in anything. Now what...
I did notice alot of caked on fluid under the front differential right by the drive shaft. Could this be my problem? What do you good and knowledgeable people think?
Here are some pics...
1990 Wrangler Laredo - Crashed
2000 Grand Cherokee Limited - Sold
1999 Wrangler sport - Current
ackliant is offline
post #2 of 10 Old 03-13-2014, 10:52 AM Thread Starter
ackliant
bump
ackliant is offline
post #3 of 10 Old 03-13-2014, 11:03 AM
alfaitalia
The top picture shows the joint is knackered. You can see the torn rubber that should go right up to the shaft. Mine looked like that when it went and has a constant whine with the odd rumble. New shaft time. Go double cardan if you can....having said that I didnt and the new one was cheap enough not to worry about. 10,000 miles and going strong at about 2.5 inch of lift. About 110 on Ebay (about $180).
You also need to get that pinion seal done and keep a check on the oil level until you do.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #4 of 10 Old 03-13-2014, 12:18 PM Thread Starter
ackliant
If I was to go junkyard shopping, what shafts would be compatible for a double cardan? I also see some double cardan on ebay for a reasonable price but they're for a ZJ. Would that work?
ackliant is offline
post #5 of 10 Old 03-13-2014, 01:15 PM
ThaBeefs
from what ive read yes the zj would work, but you are going to need the slip yokes i believe in order to use a double cardan shaft
SOLD 02 WJ 4inch RCX 265-70-17 17x9 DCs
New 01 WJ Stock ... For now
ThaBeefs is offline
post #6 of 10 Old 03-13-2014, 11:16 PM Thread Starter
ackliant
Ok, I also hear alot about the length of the shaft. Is there a standard I should be looking for?
ackliant is offline
post #7 of 10 Old 03-13-2014, 11:22 PM
capthowdy575
i would replace that pinon seal to. If you have never done one try to find a wright up. you will need a torque dial indicator tool and a new crush washer.
capthowdy575 is online now
post #8 of 10 Old 03-14-2014, 10:49 PM Thread Starter
ackliant
I found a double cardan shaft but it came from a 247. Would this work for me since I have a 242? I know I would need to get the yokes but i'm more concerned with the length.
ackliant is offline
post #9 of 10 Old 03-20-2014, 07:56 PM Thread Starter
ackliant
Ok so I've been doing a lot of research and went ahead with the double cardan ds that came from a 2004 gc with a 4.7 and 247. It's my understanding that it should be compatible. The next thing is to get the yokes for both the axle and tc side. Now what should I look for??
ackliant is offline
post #10 of 10 Old 03-20-2014, 09:03 PM
veiri86
2003 WJ
For the yokes, Nick (kolak) is your man. I got four yokes from him for my WJ's.
Sent from ME
R.I.P ratmonkey
Build thread:
01' 4.7 Limited WJ 5" lifted, Rubicon Express 4.5" coil springs with IRO critical path setup and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), JKS HD tie rod (MOOG problem solver Ends), JKS HD drag link (Moog Probel solver Ends), 4.56 Yukon ring and pinion, Moog HD SSD107 Steering Stabilizer, IRO Front drive shaft conversion, Stillen slotted rotors all around with Stillen brake pads, IRO adjustable A-Arm, 3" all the way Kolak Exhaust with High flow Magnaflow Cat. Converter and Flowmaster Super 50 Muffler, 285/70R17 AT Kumho (33") on 17" BlackWheel rims 909B, K&N Cold air intake, Four nozzles Bosch injectors, and Flashpaq 3780.
03' 4.7 H.O WJ 3" lifted, OME HD with 0.5" Coil spacers and Bilstien 5100 shocks all around, JKS adjustable Trackbar (KOR bushings), Moog Problem solver TRE's, IRO Front drive shaft conversion, IRO adjustable A-Arm, High flow magnaflow mini cats, high flow magnaflow cat, Flowmaster Super 44 muffler, 265/65R17 AT Yokohama on 17" Rays rims, and Flashpaq 3780
veiri86 is offline
