Another bulb thread - Cluster this time - JeepForum.com
post #1 of 10 Old 12-04-2012, 10:47 AM Thread Starter
NorthernStang
Question Another bulb thread - Cluster this time
What bulb are you using to replace the cluster illumination bulb?
http://www.wjjeeps.com/gauges_wh_5e.jpg
According to WJJeeps.com, those bulbs are #103, but they are nowhere to be found in my area.
From my research on the net, they are replace by PC121 and then by GE882
NorthernStang is offline
post #2 of 10 Old 12-04-2012, 11:08 AM
mycreativename
Sylvannia #74 I believe was what I used.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #3 of 10 Old 12-04-2012, 06:27 PM
multmigs
2003 WJ
or LED?
multmigs is offline
post #4 of 10 Old 12-05-2012, 07:39 AM Thread Starter
NorthernStang
Originally Posted by multmigs View Post
or LED?
Granted I could use LEDs, but then again what would be the bulb number?
post #5 of 10 Old 12-08-2012, 09:41 AM Thread Starter
NorthernStang
So finally I got Sylvania #24LL.
They're slightly brighter but does the job.
post #6 of 10 Old 12-08-2012, 10:26 AM
03azwj
2003 WJ
http://www.superbrightleds.com/morei...edge-base/228/
I used these in mine. Came out great I think.
3" OME HD springs, Bilstein 5100, JKS adjustable trackbar, Moog SS, IRO UCA'S & LCA'S, 3/4" front and rear spacers, BFG M/T km LT255/75R17, JK Rubicon takeoffs, 8K HIDS Hi's & Lo's. full Rockford Fosgate set-up, blue l.e.d. interior, clumsy driver
03azwj is offline
post #7 of 10 Old 12-08-2012, 12:24 PM
oaklyjeep10
i used these in mine. Came out great i think.
x2
RCLAs | IRO 6.5" springs| Nitto Trail Grapplers 35s | Smitty built 8000 | Custom front Bumper | Complete sound system 2 12s | BTF cover and truss (rear) | Custom sliders | Flashpaq
oaklyjeep10 is offline
post #8 of 10 Old 11-01-2013, 08:36 PM
Dezdon
Instrument bulb number confusion..
Hi, I see in my instrument cluster, I have a smaller size bulb an then a larger. The dealer says they are PC74 an PC121 but wont "special order them for me unless I buy 20 total.
Napa only had the smaller size bulb. But I need the larger ones.
I would be interested in doing the LED swap out but the ones that were posted above in this thread, linked to a "Angle Wedge Base" LED. (they look great though!) How would that work with the "insert and twist: type socket hole on the instrument cluster? I dont see how they would "plug in".
thx All .
Sand is for people unable to navigate objects.
1st Jeep I ever drove or worked on.....the M151A2.
Dezdon is offline
post #9 of 10 Old 11-02-2013, 11:50 PM
03azwj
2003 WJ
Originally Posted by Dezdon
Hi, I see in my instrument cluster, I have a smaller size bulb an then a larger. The dealer says they are PC74 an PC121 but wont "special order them for me unless I buy 20 total. Napa only had the smaller size bulb. But I need the larger ones. I would be interested in doing the LED swap out but the ones that were posted above in this thread, linked to a "Angle Wedge Base" LED. (they look great though!) How would that work with the "insert and twist: type socket hole on the instrument cluster? I dont see how they would "plug in". thx All .
Pc74 in the gauges just plug and play check out superbrightleds.com that's how I did my entire led swap.
03azwj is offline
post #10 of 10 Old 11-10-2013, 08:01 AM
Dezdon
Thank you for the reply and info. Ill look into these.
Dezdon is offline
