For all those with "memory seat disabled" message - JeepForum.com
post #1 of 19 Old 06-28-2013, 06:46 AM Thread Starter
maloj2003wj
2006 WK
So yesterday, my evic started giving me messages while driving "Memory seat disabled", "Vehicle not in park"...before that i was messing around with the junction box. I have a yellow wire in front of the junction box, which apparently did not have a tight connection. So i just messed around with for a little and everything is fine now. Here is what it looks like. Hope this helps someone. Shoot... Cannot attach pictures for some reason.. Will try later on
2006 WK LIMITED|5.7 HEMI
maloj2003wj is offline
post #2 of 19 Old 06-28-2013, 07:19 AM
Darnice
Be Carefull messing with YELLOW wires, they tend to be for the airbag system. If you do, disconnect battery and wait a few min before messing with any yellow wires.
Darnice is offline
post #3 of 19 Old 06-28-2013, 09:17 AM
imaguy3
Are you sure you didn't accidentally bump the memory seat buttons with your arm? I've done that before.
EvilEagle - "Imaguy3 just made everyone in this thread his *****."
imaguy3 is offline
post #4 of 19 Old 06-28-2013, 09:31 AM
thechainrule
Im getting this error now too. What exactly did you do to get it to go away?
thechainrule is offline
post #5 of 19 Old 06-28-2013, 11:37 AM
imaguy3
FYI, if you push the button when the car is in gear you will get that message. The memory seats are automatically disabled whenever the car is in gear, the only work in park.
imaguy3 is offline
post #6 of 19 Old 06-28-2013, 11:58 AM Thread Starter
maloj2003wj
2006 WK
I know that if you push the button ehile the car is in gear you will het that message. But if that wire has bad connection your doors will also not lock after you turn the key. I'm not sure why but i'm not able to upload the pictures. Let me do it through photobucket.
post #7 of 19 Old 06-28-2013, 11:59 AM Thread Starter
maloj2003wj
2006 WK
http://i128.photobucket.com/albums/p...ps5ea15986.jpg
Right here
post #8 of 19 Old 06-28-2013, 01:42 PM
imaguy3
Originally Posted by maloj2003wj View Post
I know that if you push the button ehile the car is in gear you will het that message. But if that wire has bad connection your doors will also not lock after you turn the key. .
Yeah, I was saying that for the person that posted above me.
What do you mean by the doors locking when you turn your key? Most cars have automatic locks that occur when you put it in gear or reach a certain speed. I personally disabled mine through the EVIC
imaguy3 is offline
post #9 of 19 Old 06-28-2013, 02:16 PM
webby88
I had the same message coming up on my evic ('00 4.7 laredo) and I dont have memory seats. The message came and went for the longest time and I fixed it by chance when I did my 'big 3' upgrade to 0 gauge wires.
I updated these major wires, (+) alternator to battery, (+) battery to pdc, (-) battery to engine block, (-) battery to chassis and besides for bettwe overall electrical performance in the dub the message stopped coming up.
I chalk it up to voltage fluctuations due to high resistance in the factory wiring, also corrosion buildup on the battery terminals, which is causing the BCM to throw out random messages.
'03 Grand Cherokee Limited 4.7 QD - DD
'00 Grand Cherokee Laredo 4.7 QT - Shes Alive!
webby88 is offline
post #10 of 19 Old 06-28-2013, 05:02 PM Thread Starter
maloj2003wj
2006 WK
My previous Laredo locked doors when i recahed 15mph. This overland is annoying. Once you turn the key in the ignition all doors lock after the beeps... My friends infinity qx does the same thing. I'm not sure if that is factory or one of the previous owners had an aftermarket remote unlock and it happened after it was removed. If anybody has a cure for this please let me know!
post #11 of 19 Old 06-28-2013, 05:08 PM
imaguy3
Once you turn the key in the ignition all doors lock after the beeps... . If anybody has a cure for this please let me know!
Use your EVIC to disable it... scroll through the menu until you see something like "automatic locks" or something, then hit the "step" button to switch it to off/no
imaguy3 is offline
post #12 of 19 Old 06-28-2013, 06:00 PM Thread Starter
maloj2003wj
2006 WK
I tried when I first got the jeep. Does not work.
post #13 of 19 Old 06-28-2013, 06:25 PM
DarkStarr
2003 WJ
Yea that seems aftermarket. My 2003 Overland locks at 15 not with the key.
DarkStarr is offline
post #14 of 19 Old 06-28-2013, 06:48 PM
jpaytoncfd
locking with the key is an aftermarket remote start or alarm. look under the dash it would be there. you'll see lots of spliced wires.
jpaytoncfd is offline
post #15 of 19 Old 06-29-2013, 05:32 AM Thread Starter
maloj2003wj
2006 WK
Yea i have noticed that too when i got this jeep. It has a lot more wiring under the dash than my previous laredo. But i have to figure out which wires actually go where... Anybody has any pointers?
