All courtesy lights are lit - JeepForum.com
post #1 of 4 Old 03-30-2010, 11:09 AM Thread Starter
eschapiro
Hi.
Suddenly, in my 2000 WJ all interior lights are lit, always. It does not change if I open/close any door. If I force interior lighting on, it only lights a little brighter.
It´s weird, because if some door switch would be malfunctioning, the VIC should warn me of that.
Any experience with it?
Any hint ?
Thanks.
David.-
eschapiro is offline
post #2 of 4 Old 03-30-2010, 11:28 AM
narnwv
narnwv's Avatar
Just to make sure, your switch on the headlight stick isn't all the way forward is it? Twist it backward and report back the results.
narnwv is offline
post #3 of 4 Old 03-30-2010, 11:39 AM Thread Starter
eschapiro
Just did it
Hi, thanks for your answer.
I twisted it all the way back, but save for dimming instrument lights, the courtesy light´s problem just remained the same.
Any hint ?
David.-
post #4 of 4 Old 03-30-2010, 01:09 PM
narnwv
narnwv's Avatar
Are the door lights and under dash lights lit as well? If not, then I would manually push each overhead light (cargo light too). If all the lower lights are on as well, then it sounds more like a bad door switch some where.
narnwv is offline
Where to buy courtesy lights? UltimatE ZJ Grand Cherokee Forum 2 09-19-2009 06:59 AM
courtesy lights on all time when key is off sdowney717 ZJ Grand Cherokee Forum 7 08-24-2009 10:46 AM
Courtesy Lights 97DCZJ ZJ Grand Cherokee Forum 2 05-10-2009 09:04 PM
courtesy lights problem bestgabe ZJ Grand Cherokee Forum 2 10-16-2008 12:34 PM
No Courtesy Lights nccherokee ZJ Grand Cherokee Forum 2 12-30-2006 06:05 PM
