All advice welcome: no compression in #2 Cylinder - Page 2 - JeepForum.com
post #16 of 34 Old 08-24-2012, 05:18 PM
Cirruslydakota
^ I was thinking the same thing. Honestly it doesn't look too bad (as long as the cylinder wall isn't damaged) so I'd throw a new slug in it and new heads and run it. It's a shame this happened so far away from home, otherwise it would be an easy repair.
Sent from inside my 4.0.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #17 of 34 Old 08-25-2012, 09:48 AM
oldfamilyguy
Then the money you spent on having the one head pulled isn't a total waste either. A few years ago I was having trouble finding 1 piston, could only find full sets available. Ending up hooking up with a guy who needed all 6 for a 3.7. So we bought a full set for a 4.7, and I got 1 from him. He needed 6 but I don't know whatever happened to the leftover 1.
oldfamilyguy is offline
post #18 of 34 Old 08-28-2012, 02:57 PM Thread Starter
Wayne94552
Thanks again for the ongoing suggestions. It helps to get other perspectives since my judgment on this seems a little cloudy due to the added stress this has brought about.
I like the sound of replacing one piston, especially if I can get the rod loose from underneath. I have a good machine shop I've used near my house a bunch of times. If the machinist knows this "dropped seat" issue and thinks he can get a replacement seat to stick I may just do this as cheap as possible. The search for a single piston begins :-) I've got the 3 day road trip planned for Sept 14-16. Hopefully the weather in Boise holds out so my daughter's bike riding isn't too uncomfortable.
Wayne94552 is offline
post #19 of 34 Old 08-28-2012, 06:56 PM
super98lsc
is the piston that bad or just a small ding? Walls clear and bearing not damaged? This stinks....sorry to hear the news
. I have an 02 limited v8 I bought to fix and sell same story #2 intake stuck partially open.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #20 of 34 Old 08-28-2012, 08:17 PM
kc2mrg
if you can only find a set of pistons and you have the time, you might want to put them all in, just so you know you might not have another piston issue down the road
2004 Grand Cherokee Laredo 4.0
Rusty's 2.5" coil/shock lift
265/70/16 General Grabber AT2's
Superchips 3875 Flashpaq
Flowmaster exhaust
West Virginia Jeep Club member
JEEPINWV.COM
kc2mrg is offline
post #21 of 34 Old 08-29-2012, 02:03 PM
jclaudii
If you can get the oil pan off, then you can always try the "cheap" approach by just replacing the one piston or at least pull it out and see what it looks like for the cylinder walls. use www.car-part.com to see if you can find a yard close to you that has a engine and or a jeep part, like a air bag or something. Basically you just want to get the parts listing for various yards. Can call and ask if they have any broke or core engines that are in good shape so you can have piston. While you calling you can also ask about the heads, if you can find a used set of heads, you can drop them off and get a complete valve job for about $100 or so. I look forward to seeing a thread with your progress and woes. Don't give up! you can do it yourself!
if you wait a few weeks, you can find some nice flood cars from the southern half of the states
jclaudii is offline
post #22 of 34 Old 09-26-2012, 02:05 PM Thread Starter
Wayne94552
Hi All,
Well my son and I made the trip to Boise and back without any troubles. IT was almost exactly 1300 miles round trip. I've seen enough of eastern Oregon to last a lifetime.
The gouge in the piston is deeper than the pictures show. It would definitely burn hot. This weekend I'm going to take a look at the possibility of replacing the Piston without pulling the block. If it looks feasible I may go that route.
post #23 of 34 Old 09-30-2012, 10:29 PM
oldfamilyguy
Hey happy to hear you got it back home. I don't know if you can get #2 piston out that way. But I can't say for sure one way or the other. I tried searching on it. I was hoping you can but it seems more likely not than do able. Please look into it. You have suffered enough already and it would certainly add to your misery to pull the oil pan first then find you can't get the piston out. I just hope theres some happy ending to this one way or the other.
post #24 of 34 Old 05-03-2013, 12:22 AM Thread Starter
Wayne94552
Well after a lot of thinking, pricing and talking this over with my daughter decided on a a full rebuild of her motor. It's been a little slow going as we got the parts together, machine work and our schedules don't mesh well. My daughter wants to learn how to rebuild a motor so like any dad would, I said hell yeah. It's a beautiful thing to see my daughter with a torque wrench.
I have a question for this group concerning rod bearings. Tonight we got the rings on the pistons after doing all the gap and groove clearance checks. As we were getting ready to drop the first piston I bust open the King Rod Bearings (CR8030SI) and find all 16 bearing halves do not have the tang on them to prevent bearing spin. I'm no engine rebuild guru, but I've built a few and have never seen a set of rod or main bearings without the tang to prevent bearing spin. I'm thinking this was a packaging mistake and maybe I got two sets of top halves or something. Has anyone done a 4.7 rebuild where there wasn't a tang on the rod bearings? Picture provided, all 16 bearings are like the one shown. It scares the crap out of me just thinking of installing the bearings like this. Double checking the King Bearing part number on various sites checks out but my gut says this situation is wrong. As always, all replies and help is welcome.
post #25 of 34 Old 05-03-2013, 02:56 AM
CarlJH
2003 WJ
I saw a uk program called the garage. They did the bearings on a jeep and they were the same as yours. The dealer said they were correct and you need a special tool to put the tang in the edge. They improvised with what tools they had to hand
CarlJH is offline
post #26 of 34 Old 05-03-2013, 06:21 AM
car5car
2002 M-38
If engine has a problem, fix that problem!
Broken piston, replace piston, valve seat fell off, replace valve seat!
I just repaired 4.7 and 4.0 WJ engines.
Your engine can be easily repaired, no big deal.
$18 piston, $5 each valve.
Be very careful with upper chain guide bolt, previous mechanic broke it in my car. He also broke a few valves by bad timing.
IMPORTANT!!!
timing chain installation require special tool, holding cam chains to a sprocket.
I used some rope, which I pulled out after installation.
I'll make a picture if you need it.
Do not replace good bearings!
Only use new rings on new piston!
Lap valves to check, if machine shop is needed.
Your daughter is very pretty.
01 XJ 2wd 4.0
car5car is offline
post #27 of 34 Old 05-03-2013, 11:04 AM
Double E
Double E's Avatar
I wanna wrestle!
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #28 of 34 Old 05-03-2013, 11:47 AM
car5car
2002 M-38
Originally Posted by Double E View Post
I wanna wrestle!
Search Ronda Rousey on you tube.
01 XJ 2wd 4.0
car5car is offline
post #29 of 34 Old 05-03-2013, 12:51 PM
Darnice
Umm too much bedplate goo? a light thin bead, so much there it might break off and get into things
Darnice is offline
post #30 of 34 Old 05-03-2013, 12:56 PM
VinceWj
2500 for an engine with a 4years OR a million mile warranty.... go for it, i wouldnt even bother trying to fix that one
Coca-Cola over Pepsi
Monster over Redbull
Jeep over my neighbor lowriding SHIvic
VinceWj is offline
Low compression cashinout WJ Grand Cherokee Forum 9 04-23-2012 01:57 PM
No Compression In Cylinder 8, But No CEL berndog67 WJ Grand Cherokee Forum 3 04-14-2012 06:08 AM
Throwing a P0302 engine code, cylinder #2 Cylinder Misfire Detected 99_wj_QD WJ Grand Cherokee Forum 4 01-24-2012 01:32 PM
Compression? KBag WJ Grand Cherokee Forum 2 05-16-2011 11:30 PM
No compression in ANY cylinder? manofmany WJ Grand Cherokee Forum 21 09-17-2010 02:26 PM
