Alarm wont stop - Page 3 - JeepForum.com
post #31 of 49 Old 09-17-2013, 06:16 PM
Big_Wall
2010 JK Wrangler
It's apparently in the dash. They asked me if I was getting water in the dash. I'll ask them when I pick it up tomorrow. They just called back to say that while replacing the powertrain control module fixed all the other problems, the key would still not shut off the alarm. He said that it is extremely common for the wireing harnes in the door to become brittle and for the wires to break inside the insulation. They are now tracing down what wires are broken and splicing in new wire. My condensor drain hose was also apparently clogged and that is where the water in the floorboards was coming from. It would drain some but not all the way. With all the humidity we have lately the tank overflowed. They are fixing that for me for free.
I also need to replace the carrier bearings in the front and rear differentials. That's another $2600 if I have them do it. He said that it can wait for a while though. I knew that was coming and had been saving money for it. I just had to keep fixing other things and hadn't been able to get that done yet.
Big_Wall is offline
post #32 of 49 Old 09-17-2013, 06:49 PM
Big_Wall
2010 JK Wrangler
The PCM is in the engine compartment on the left side between the coolant overflow tank and the firewall. After reading what this does, I need to ask them exactly what this has to do with the problem.
Big_Wall is offline
post #33 of 49 Old 09-17-2013, 09:26 PM
rdkendrick
2003 WJ
After reading, here, with all the rain there, and another thread, where someone washed their engine bay, I wonder if I shouldn't water-proof my PCM somehow. Wrap it in plastic, or spray water repellant into it. WD-40 is supposed to be a water repellant. I don't know about wrapping it in plastic, though, as it could overheat it.
Sent from my iPad using my fingers
rdkendrick is offline
post #34 of 49 Old 09-17-2013, 11:31 PM
Big_Wall
2010 JK Wrangler
Come to think about it, I did wash out my engine compartment a few days before this happened. I had the upper radiator hose blow and was trying to wash out all the anti-freeze.
Big_Wall is offline
post #35 of 49 Old 09-18-2013, 03:34 PM Thread Starter
wingman27
Any word on your fix yet? Mine is still no where!! So frustrating and mad wit this and my break in!!
My New Build.. http://www.jeepforum.com/forum/f22/2001-grand-cherokee-1269875/
wingman27 is offline
post #36 of 49 Old 09-18-2013, 03:47 PM
Thomahawk
Actually its the security alarm switch That tells the BCM if door Are locked or unlocked, and arm or dearm the alarm.
The BCM is located under the dash next to the fuse box.
Idk if the PCM have anything with this to do,,,
From wjjeeps.com
The PCM is a pre-programmed, triple microprocessor digital computer. It regulates ignition timing, air-fuel ratio, emission control devices, charging system, certain transmission features, speed control, air conditioning compressor clutch engagement and idle speed. The PCM can adapt its programming to meet changing operating conditions.
The BCM utilizes integrated circuitry and information carried on the Programmable Communications Interface (PCI) data bus network along with many hard wired inputs to monitor many sensor and switch inputs throughout the vehicle.The BCM supports many body electrical features such as Interior Lighting, Exterior Lighting, Intermittent Wipers, Remote Radio, Accessory Delay, and Heated Seats.
Buildthread
Thomahawk is offline
post #37 of 49 Old 09-18-2013, 07:53 PM
Big_Wall
2010 JK Wrangler
They replaced the PCM and fixed the wireing in the door. He said that the alarm also sends inputs to the PCM. The wires to the driver's door are known to get brittle and break inside their insulation over time. My alarm wouldn't recognize the key in the door so some of the broken wires could definitely have been for the security alarm switch
Big_Wall is offline
post #38 of 49 Old 09-18-2013, 09:18 PM Thread Starter
wingman27
I'm no where closer. All wires in door are fine still nothing came up wit codes that lead nowhere. So PCM fixed your problem?.. Didn't change the bcm?
post #39 of 49 Old 09-18-2013, 09:35 PM
Big_Wall
2010 JK Wrangler
Yes, they replaced my PCM. That fixed everything other than the key not shutting off the alarm when I used the key in the door. I looked at the sunroof drain hoses when I got out home tonight. They were all broken and brittle. I think that is where all the water was coming from. I'm going to replace them with vinyl tubing tomorrow.
Big_Wall is offline
post #40 of 49 Old 09-18-2013, 09:37 PM Thread Starter
wingman27
So how do you shut off the alarm?.. I'm sorry but I'm confused bout ya key issue still..
post #41 of 49 Old 09-18-2013, 09:53 PM
Big_Wall
2010 JK Wrangler
After replacing the PCM the fob worked again. Everything worked properly other than unlocking the door with the key wouldn't turn off the alarm. Replacing the broken wiring made it so that unlocking the door with the key would also turn off the alarm. One of the broken wires had to go to the security alarm switch because it works now
Big_Wall is offline
post #42 of 49 Old 09-18-2013, 10:00 PM Thread Starter
wingman27
Ok cool imma get one tomorro and hope for the best thank you
post #43 of 49 Old 09-18-2013, 10:05 PM
Big_Wall
2010 JK Wrangler
Good luck. Let us know how it goes.
Big_Wall is offline
post #44 of 49 Old 09-18-2013, 11:58 PM
Big_Wall
2010 JK Wrangler
Here is what my repair order says: PCM shorted on bus 3.50. Diagnosed, replaced and programmed PCM. Repaired wires in driver's door
Big_Wall is offline
post #45 of 49 Old 09-19-2013, 12:47 AM Thread Starter
wingman27
So you do have to reprogram the PCM!? Ugh
