Alarm wont stop - Page 2 - JeepForum.com
post #16 of 49 Old 09-16-2013, 01:25 PM
Thomahawk
Originally Posted by wingman27
Got the part out now have to wait til tomorro for new one to get here no place in Colorado ha one. Bs!!
Use a ohm meter and test the resistance in lock and unlock position,,,,
After i changed mine,i saw the old one was dirty inside, might Get lucky with some electro cleaner, worth a try,,,
Buildthread
Thomahawk is offline
post #17 of 49 Old 09-16-2013, 02:05 PM Thread Starter
wingman27
Don't have one on hand with me and is rather pay the money then have it work for a month then act up again. I get parts at cost so not human get super screwed and if that's not the problem il take it back but thanks il update tomorro
My New Build.. http://www.jeepforum.com/forum/f22/2001-grand-cherokee-1269875/
wingman27 is offline
post #18 of 49 Old 09-16-2013, 09:41 PM
Panocha
Originally Posted by Big_Wall View Post
My Jeep did exactly the same thing today. I unlocked the doors with the fob, opened the rear hatch and the alarm went off and will not shut off. Double locking/unlocking the passenger door, trying to unlock the driver's door with the key, and trying to start the car will not shut the alarm off. I opened up the driver's door panel and there does not seem to be any moisture in the door, but my front passenger and driver's side floorboards are soaked. Water is getting in somewhere.
I'll post up if I find the solution to the problem.
My floor board gets wet on the passenger side. When I had a similar problem, only my horn was going off. I had to disconnect both horns to get them to stop. Reconnected them a couple weeks later and it hasnt happened yet, even with the rain. I wonder if there is some kind of relay on the passenger side that is getting wet and setting them off.
Panocha is offline
post #19 of 49 Old 09-16-2013, 09:56 PM Thread Starter
wingman27
I'm about to release the break and have it roll down the hill and hit the flood so somehow I don't have to deal with my moded out bad *** wj but.....
post #20 of 49 Old 09-16-2013, 11:55 PM
Big_Wall
2010 JK Wrangler
Lol. My wife wants to light mine on fire.
Big_Wall is offline
post #21 of 49 Old 09-17-2013, 12:11 AM
Mav-Jason
My wife won't stop taking mine! And leaving her precious 08 galant in the driveway for me... pissin me off!
Jay.
Black '99 WJ 4.0 Selec-Trac~ OME MDs w/ .75" Spacers, Bilseins, JKS ADJ. TB,
Moog SS, Moog HD TREs/ Sleeves, Ext Rear Links, 16x8 Ion Alloys, 32" BFG Wrangler Authorities
Mav-Jason is offline
post #22 of 49 Old 09-17-2013, 02:34 PM
rdkendrick
2003 WJ
For some reason, my wife doesn't like to drive mine. I guess I am lucky :-)
Sent from my iPad using my fingers
rdkendrick is offline
post #23 of 49 Old 09-17-2013, 02:42 PM Thread Starter
wingman27
Jeep for sale. 2001 wj lifted wit 33s and 20 inch rockstar wheels. No longer has a passenger side window or a stereo or subs!! I'm having this alarm issue still not fixed so I can't get into my car with out the alarm goin off but some a**holes can get all my expensive **** out!!
post #24 of 49 Old 09-17-2013, 03:03 PM
Thomahawk
Auch That sucks, guess you would die to have a Viper 2way alarm,,,?
Buildthread
post #25 of 49 Old 09-17-2013, 03:07 PM Thread Starter
wingman27
Talk more about the alarm. I had one wen I bought the car but they ha to unhook it to put in my interlock. I want an alarm that senses wen someone is in it or wat not and messages my phone as well.. Or something.
post #26 of 49 Old 09-17-2013, 03:53 PM
Big_Wall
2010 JK Wrangler
Dealership just called and said that they had the alarm problem narrowed down to the powertrain control module and asked if water was coming in somehow. I'm definitely getting water inside. My driver and passenger side floorboards are soaked. They are going to replace the module and look for where the water is coming from. So far I'm looking at over $1000. I'll post updates as I get them.
Sorry to hear you got broke into.
Big_Wall is offline
post #27 of 49 Old 09-17-2013, 04:11 PM Thread Starter
wingman27
Just replaced the security alarm switch and still same problem. I need help now!!!
post #28 of 49 Old 09-17-2013, 04:12 PM
Thomahawk
https://www.viper.com/ShopViperProdu...tegoryCode=104
I made a write up on the install, check out my threads, its 2 Way telling you whenever its triggered, with Siren or silent (bat mode).
My is (was) adjusted so sensitiv its triggered of heavy rain.
You gotta love That remote start function, in very cold or ears days. Simply set your AC at auto and temp wanted, if cold will heat up, if hot will cool down before entry.
Rear Window defrost can also be wired up.
Sorry to hear That the switch didnt solve it, i sm runing out of ideas,,,,
Buildthread
post #29 of 49 Old 09-17-2013, 04:16 PM
Big_Wall
2010 JK Wrangler
See my post above
Big_Wall is offline
post #30 of 49 Old 09-17-2013, 04:21 PM Thread Starter
wingman27
Where is module??
