Aircon Woes.. - JeepForum.com
post #1 of 15 Old 06-14-2013, 10:27 AM Thread Starter
MadderThanMax
Wj Aircon Woes..
Vehicle: 2001 2.7CRD WJ Limited (Down Adam!!)
So we have a little bit of a heat wave up here in sunny Scotland and.. My Aircon don't work..
So I took in and had it recharged and that went well, nice new gas in it etc except the aircon clutch ain't getting a signal to engage! At first we thought because its had a new heater control panel that it would have to be coded to the vehicle -not so according to the stealers its a plug in and play job. I was then told it was a broken wire usually in and around the control panel.. not so, pulled the dash apart to day and tested each wire and all was okay. Next was the AC PCM in the engine bay - swapped that with a reliable one (Works in another car) and nope! No talky.. anyone any ideas.. want my aircon back please ;-)
MadderThanMax is offline
post #2 of 15 Old 06-14-2013, 12:46 PM
CarlJH
2003 WJ
There's a pressure switch somewhere try giving it a lite tap to see if the contacts at sticking
CarlJH is offline
post #3 of 15 Old 06-15-2013, 11:46 AM Thread Starter
MadderThanMax
Bump anyone??
post #4 of 15 Old 06-15-2013, 11:54 AM
austin6137
1990 XJ Cherokee
Is the system charged, I think if the r134a leaks out the clutch wont engage. But I could be wrong
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #5 of 15 Old 06-15-2013, 12:09 PM
alfaitalia
Check the low pressure switch. It failed on my mates 4.slow....so they do go. If the system thInks the pressure is too low it won't let the compressor engage to protect itself.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #6 of 15 Old 06-15-2013, 12:09 PM Thread Starter
MadderThanMax
@ Austin 6137...
"EEEEEEHHHHHH... Wrong Answer"
Says so in First line third paragrapgh....thanks for input though ;-)
post #7 of 15 Old 06-15-2013, 12:11 PM Thread Starter
MadderThanMax
Hi Dean.
No. It took a full charge and held, which surprised me for an 11year old vehicle..
post #8 of 15 Old 06-15-2013, 12:11 PM Thread Starter
MadderThanMax
Where is the switch and any photos mate??
post #9 of 15 Old 06-15-2013, 12:15 PM
alfaitalia
Really??? Read it three times and still can't see any mention of the low pressure switch......my eyes must be going with my old age! Hope you sort it. Did not know it ever got above freezing up there any way!
post #10 of 15 Old 06-15-2013, 02:13 PM Thread Starter
MadderThanMax
My bad D, misread your postin' I thought you meant that it had low pressure and didn't take much gassin'. Where is the switch??
Weather humour?? I'll send you a bucket of rain and a handful of midges for your inevitable drought you always have..
post #11 of 15 Old 06-15-2013, 03:43 PM
Mike2909
Always thought Scottish aircon was opening a window.
Mike2909 is offline
post #12 of 15 Old 06-15-2013, 04:12 PM
alfaitalia
Cant find a pic of it in situ but the part no is 5073 617aa...and it looks like this:
http://www.ebay.co.uk/itm/Dodge-A-C-...#ht_1714wt_721
Will try and get pic tomorrow....if I can get away from the family for five minutes (Fathers Day and Im a son and a father!)
post #13 of 15 Old 06-15-2013, 04:37 PM
js12278
That is the high pressure cut out switch., Mounted on the accumulator alongside the battery in a 4.0 engine bay.
http://www.rockauto.com/catalog/more...312&cc=1431779
js12278 is offline
post #14 of 15 Old 06-16-2013, 02:28 AM
alfaitalia
Yes but according to my parts list, high and low pressure switch are one and the same........ more research I think.
post #15 of 15 Old 06-16-2013, 03:56 AM Thread Starter
MadderThanMax
Thanks Guys..
