AirBag light randomly turns on - JeepForum.com
post #1 of 23 Old 02-23-2011, 02:01 PM Thread Starter
oujea
2009 WK
Hello
Airbag light and chime randomly turns on when driving, it stays few seconds, and then turns off. I checked for Airbag control module codes with Launch X431 diagnostic tool, and i get this trouble code:
DRIVER SQUIB #1 CIRCUIT OPEN
What it can be caused by? I think the clockspring is ok, because all other functions are working: steering wheel controls for cruise control, horn, power steering etc...
oujea is offline
post #2 of 23 Old 02-23-2011, 02:31 PM
FFuries
Had a 1996 Jeep ZJ do the same thing, turned out to be a bad ignition switch. Reached up under the switch and the cover was distorted, had bare wires showing when we got it apart. Never figured out how it got that way. But replaced the switch, worked great until my son tangled with a Surburban, the Jeep lost.
Mike
USAF Retired
Mike in Florida
USAF Retired
Stock 1996 Jeep ZJ Limited
4.0 L
Stock 2000 Jeep WJ Laredo
4.7, Loaded W/ Every Option Available
FFuries is offline
post #3 of 23 Old 02-23-2011, 02:34 PM Thread Starter
oujea
2009 WK
OK, thank you very much, I'll check it. Has someone another had this problem? Btw reason more why I think that it wasnt caused by clockspring is that it doesnt matter if I move steering wheel on not, sometimes it comes on when I'm driving straight, and without touching steering wheel.
oujea is offline
post #4 of 23 Old 02-23-2011, 02:46 PM
boomersoonerGC
Likely the clockspring. Easy fix, just gotta remove the steering wheel and put a new one on.
boomersoonerGC is offline
post #5 of 23 Old 02-23-2011, 02:49 PM Thread Starter
oujea
2009 WK
But usually people have another problems connected with clockspring (horn, steering wheel controls etc), but in my case, everything else works. And airbag lights comes on sometimes even when i'm driving straight, without touching steering wheel? Does it still mean that it can be caused by clockspring?
oujea is offline
post #6 of 23 Old 02-23-2011, 03:06 PM
boomersoonerGC
Its possible, but that code is almost always the clockspring.
Here are the typical causes.
CLOCKSPRING, DRIVER AIRBAG CIRCUITS OPEN
DRIVER AIRBAG LINE 2 OPEN
DRIVER AIRBAG LINE 1 OPEN
ACM, DRIVER AIRBAG CIRCUIT OPEN
I would start with the clockspring.
post #7 of 23 Old 02-23-2011, 03:18 PM Thread Starter
oujea
2009 WK
i have to replace clockspring? there are no connectors or possibly bad contacts?
oujea is offline
post #8 of 23 Old 02-23-2011, 03:41 PM
boomersoonerGC
The clockspring is the connector. It allows your electronics to remain connected while the steering wheels turns. Not unusual for them to go out considering the wear that is put on them.
post #9 of 23 Old 02-23-2011, 03:51 PM Thread Starter
oujea
2009 WK
So, I guess i should buy new part and replace it, and see how its going then?
oujea is offline
post #10 of 23 Old 02-23-2011, 03:56 PM
boomersoonerGC
Unfortunately thats how it goes.
Out of all the things that could be wrong, thats likely the cheapest. Otherwise you are getting into actual airbag wiring and acm stuff.
post #11 of 23 Old 02-23-2011, 03:59 PM Thread Starter
oujea
2009 WK
Well, that clockspring isnt too cheap on Rockauto.com, so i think I'll wait for better days to buy it I'll check ignition switch, maybe it makes problem.
oujea is offline
post #12 of 23 Old 02-23-2011, 04:00 PM
boomersoonerGC
I have no idea where in Bosnia you would buy a clockspring, but I would imagine shipping it there would be pricey. Might be able to pick one up on ebay or something.
post #13 of 23 Old 02-23-2011, 04:03 PM Thread Starter
oujea
2009 WK
Shipping to Bosnia from USA usually costs 20 USD or more (depends of size, weight and so on). And the clockspring on rockauto is about $120, so that's why i'll wait some time before buying it : ) and in case of accident, would my airbag be activated if i have SOMETIMES this warning light on? or it won't work unless i fix it?
oujea is offline
post #14 of 23 Old 02-23-2011, 05:53 PM
boomersoonerGC
post #15 of 23 Old 02-23-2011, 05:56 PM Thread Starter
oujea
2009 WK
wow thank you, this one is pretty cheap. but seller does not offer international shipping, but anyways i'll try to find one who does. thank you for your help.
oujea is offline
Air bag light randomly comes on... and... MiZZ WJ Grand Cherokee Forum 43 01-04-2016 02:50 PM
seat belt light and airbag light xj539 WJ Grand Cherokee Forum 6 10-25-2015 06:47 AM
oil randomly low and check engine light. kingplay334 WJ Grand Cherokee Forum 11 12-20-2010 06:14 PM
02 4.7 wj randomly turns off, and high oil pressure PCJona WJ Grand Cherokee Forum 0 05-21-2010 08:52 PM
A/C Randomly Turns On Astorm WJ Grand Cherokee Forum 4 06-05-2004 06:21 PM
